![]() | Home > Technical (L322) > Crackling (?) noise from windshield corners? |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3200 ![]() ![]() |
I have the same. I thought it may be a loose screw in the airbag area of the A pillar but all was good there. I think it is the external A pilar trim. The clips are notorious for breaking expeeically after a screen replacement. Could be that? They are c. £20. |
vektory Member Since: 27 Feb 2023 Location: Vienna Posts: 21 ![]() ![]() ![]() |
Very good hints!
no, there is a 'how to' in the post somewhere. search "Pillar". |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
Mine does something similar to this too but only on really cold mornings. I had just put it down to plastic components in the dashboard corners expanding as they warmed up as the heating kicked in but will be interested to see if you guys come up with another cause for it. 2012 Westminster TDV8 4.4 Indus Silver
just been outside and checked my exterior black plastic trims.............. hey ho, not fully pressed home on leading edge. Simple palm push along the whole length and all good. No more noise!! |
Was also checking the plastic trim now....had to find out there is a little gap to the windshield. Could not push it in, so will order some new clips and install them |
Short update:
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1283 ![]() ![]() ![]() |
I found the original clips didn't hold the trim tight.
You don't happen to remember which clips you did buy, do you?
I'll have a look for you in a bit. |
check the inner part of the trim where it fits onto the windscreen (ie. nothing to do with the clips/pins on the door frame.) I found that the whole length had come away from the windscreen and needed glueing back down. |
It is true that the whole length is not completely tight to the windscreen. You did not glue the rubberlip to the windscreen, did you? The lip is still nice sitting on the plastic trim
Hi Vektory, I've just been and had a look, but I've got dozens of clips and can't remember which ones I used!!
