![]() | Home > In Car Electronics (L322) > Venture cam install in 2011 4.4 TDV8 |
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 ![]() ![]() ![]() |
I hope you get a reply as mine has the same wiring. Mercedes AMG w207
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
It's obsolete technology with a low quality camera
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Good afternoon
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
Brilliant ! just the answer I was looking for, I hadn’t had time to get this done but I hope to shortly.
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
Hi, can you tell me venture cam / cradle parts no. for L322 after 2010 year?
So are you saying you don’t have a cradle to slot the camera into? 1990 3.5 v8 defender
I trying to retrofit it.
Although I started this thread I haven’t done the installation yet I have all the parts to do it but time is my problem at the moment.
It was avaliable on 2010 onwards. Owner manual says how to use it. In parts catalogue it also exists, but no one gives proper numbers in the internet.
Ahh ok well that makes it more difficult as maybe the newer cradle could be different in some way, I’ll check the part number I have when I get home, the donor kit I have came from a 2008 which is closer to 2010 but still could be different.
2008 for sure is wrong one. it is different entertainment system. Physically looks the same, probably different software inside. |
Just looked at mine it’s xvl 500070 pva 1990 3.5 v8 defender
