Home > In Car Electronics (L322) > Venture cam install in 2011 4.4 TDV8
klf400
Hi guys just a thought, recently had my cd changer out for repair and noticed the multi plugs are behind the glove compartment for the venture cam ,
I do have a spare cam and cradle and wondering if plugged in can this be enabled with the gap tool as I see no icon in 4x4 info for it,
I believe the venture cam sort of phased out in later years for all around cameras and blind spot monitoring which mine has and would hope that there would be no conflict if it can be enabled.
Any thoughts or advice would be welcomed 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #658396 3rd Mar 2023 11:38pm
daveturbo
Cam
I hope you get a reply as mine has the same wiring. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #660000 21st Mar 2023 10:45pm
garyRR
It's obsolete technology with a low quality camera
An alternative is the rechargeable magnetic wifi/bluetooth camera which is sold at Go Outdoors. 2015 Range Rover Autobiography 4.4 SDV8
Post #660158 23rd Mar 2023 7:47pm
Shaunj69
England 2012 Range Rover Autobiography 4.4 V8 Zambezi Silver
Good afternoon
I have the same thing, So i when ahead and fitted it.
But yes i can see it on the 4x4 screen after i changed the CCF with my GAP tool, just need to get a new battery for the camera lol L322 TDV8 2011 Autobiography
Working for an OE aftermarket car parts suppler
Post #660237 24th Mar 2023 2:16pm
klf400
Brilliant ! just the answer I was looking for, I hadn’t had time to get this done but I hope to shortly.
The batteries are not cheap, you have to solder them in or spend some more and plug and play battery is available 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #660239 24th Mar 2023 2:26pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Hi, can you tell me venture cam / cradle parts no. for L322 after 2010 year?
I connected changed in iidtool venture cam to fitted + companion camera to fitted. I have Camera option on the screen, but no connection, no pairing, and no charging camera in cradle. (Camera with new battery and turns on)
Post #661183 6th Apr 2023 11:11am
klf400
So are you saying you don’t have a cradle to slot the camera into? 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #661192 6th Apr 2023 12:40pm
jimmie
I trying to retrofit it.
I have two: XVL500070PVA. Doesn't work
Post #661196 6th Apr 2023 12:59pm
klf400
Although I started this thread I haven’t done the installation yet I have all the parts to do it but time is my problem at the moment.
Shaunj69 who commented above has done it but hasn’t confirmed if it works or not,
The 2010 on I believe wasn’t available with venture cam only Al round cameras and blind spot monitoring which mine has . Having said that maybe the wiring and plugs are on the loom and can be enabled with the gap tool in the ccf file there maybe another reason for it not working such as an antenna and or a ecu controller 🤔 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #661199 6th Apr 2023 1:16pm
jimmie
It was avaliable on 2010 onwards. Owner manual says how to use it. In parts catalogue it also exists, but no one gives proper numbers in the internet.
for earlier models:
XVL500031PVA 5H42 19H289-AAPVA
XVL500050PVA 6H42 19H289-AA8PVA
XVL500070PVA 3H42 19H289-AA8PVA
XVL500090 7H42 19H289-A
for 2010 i need LR012890 (Eng no: AH42 19H442-AB) but can't find nothing with this number
Camera itself has the same number XVI500220
Post #661209 6th Apr 2023 2:11pm
klf400
Ahh ok well that makes it more difficult as maybe the newer cradle could be different in some way, I’ll check the part number I have when I get home, the donor kit I have came from a 2008 which is closer to 2010 but still could be different.
From Landrover this part I’m sure would be horrendous ££ if available 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #661211 6th Apr 2023 2:24pm
jimmie
2008 for sure is wrong one. it is different entertainment system. Physically looks the same, probably different software inside.
Post #661212 6th Apr 2023 2:27pm
klf400
Just looked at mine it’s xvl 500070 pva 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #661301 7th Apr 2023 10:54am
