Home > Technical (L405) > rear end noise
funnyguy1
United States
rear end noise
I have had this slipping sound from the rear when making left right turns and was told by my dealer the differential had to be flushed and refilled and then a module had to be reprogrammed.Has anyone had this issue and if so, is there any danger driving it as I can't get it to my dealer until 3/13. Thx!
Post #657410 22nd Feb 2023 1:37am
funnyguy1
United States
Sorry, i posted and then found the thread so i guess the question is can it cause damage?
Post #657411 22nd Feb 2023 1:44am
Phoenix
There's a chance it will put excessive load on driveshafts, CV joints, rear propshaft, transfer box and of course, the rear differential itself. I doubt it'll cause any damage as such, but it will accelerate drivetrain wear.
Post #657414 22nd Feb 2023 7:15am
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
Mines doing this funnyguy1 and is booked in to indy for same work you described next week. Do you have a link to the other thread that you mentioned in your second post please?
Post #657444 22nd Feb 2023 1:51pm
nickt68
Mine's doing this funnyguy1 and is booked in to indy for same work you described next week. Do you have a link to the other thread that you mentioned in your second post please?
Post #657445 22nd Feb 2023 1:51pm
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
I also have that sort of ripping shudder when I reaccelerate after beaking while turning left to a stop ...
My indy said there a reprogramming to do with the differential... I have a appointment scheduled Neutral
will come back once it's done
Ergo "it needs some intelligence to undestand you may not have enough"
Post #657462 22nd Feb 2023 4:47pm
funnyguy1
United States
To nickt68. I typed in "noise from rear end when turning" and it took me to a thread by pherplexed which described what needed to be done and my dealer said it is probably the same fix. FG
Post #657464 22nd Feb 2023 4:58pm
nickt68
Thanks FG, will give it a try
Post #657540 23rd Feb 2023 10:58am
This one...
https://www.fullfatrr.com/forum/topic52457.html Pete
Post #657559 23rd Feb 2023 1:19pm
nickt68
Just an update, had the oil changed and software update and (so far!) seems to have cured the problem. The indy warned me that sometimes the oil needs a second change but will see how it goes.....
Post #659312 14th Mar 2023 1:47pm
funnyguy1
United States
The issue with the rear end noise when turning left or right was the transfer case. The Dealer flushed it twice and then refilled and reprogrammed a module and everything is fine. Not sure was what causing there exact noise but it was troublesome until fixed.
Post #660042 22nd Mar 2023 3:11pm
