Home > Technical (L405) > rear end noise |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 386 |
Sorry, i posted and then found the thread so i guess the question is can it cause damage? |
22nd Feb 2023 1:44am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
There's a chance it will put excessive load on driveshafts, CV joints, rear propshaft, transfer box and of course, the rear differential itself. I doubt it'll cause any damage as such, but it will accelerate drivetrain wear. |
22nd Feb 2023 7:15am |
nickt68 Member Since: 05 Nov 2010 Location: Herts Posts: 99 |
Mines doing this funnyguy1 and is booked in to indy for same work you described next week. Do you have a link to the other thread that you mentioned in your second post please? |
22nd Feb 2023 1:51pm |
Mine's doing this funnyguy1 and is booked in to indy for same work you described next week. Do you have a link to the other thread that you mentioned in your second post please? |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 |
I also have that sort of ripping shudder when I reaccelerate after beaking while turning left to a stop ...
22nd Feb 2023 4:47pm |
To nickt68. I typed in "noise from rear end when turning" and it took me to a thread by pherplexed which described what needed to be done and my dealer said it is probably the same fix. FG |
22nd Feb 2023 4:58pm |
Thanks FG, will give it a try |
23rd Feb 2023 10:58am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8310 |
This one...
23rd Feb 2023 1:19pm |
Just an update, had the oil changed and software update and (so far!) seems to have cured the problem. The indy warned me that sometimes the oil needs a second change but will see how it goes..... |
14th Mar 2023 1:47pm |
The issue with the rear end noise when turning left or right was the transfer case. The Dealer flushed it twice and then refilled and reprogrammed a module and everything is fine. Not sure was what causing there exact noise but it was troublesome until fixed. |
22nd Mar 2023 3:11pm |
