Home > Technical (L322) > Windscreen replacement
Joiner
Australia 2003 Range Rover Vogue 4.4 V8 Galway Green
So I had a windscreen replaced. 2003 Vogue 4.4.
Since the windscreen replacement it seems the headlights are pointed really low all of the time.
Windscreen company said there is no headlight sensor as such on the windscreen, only a rain sensor, so no calibration or similar required after the replacement. Is that really the case? Headlights are almost useless at the moment. I can’t see 5m infront of me.
Post #657215 20th Feb 2023 1:48pm
does your headlight switch have an 'auto' setting?
if yes then you do have a headlight sensor .. ... - .- -.
Post #657234 20th Feb 2023 3:40pm
Phoenix
The light sensor won't affect the light output, only when they come on. It sounds to me like the headlamps are too low, possibly due to an issue with the AFS. OP, have you tried a battery disconnect/reconnect? it could be that the voltage got a bit low whilst the screen was being fitted and spiked the module when started. Obviously only a guess with no DTC's etc.
Post #657252 20th Feb 2023 7:52pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Does the L322 have a weight load adjuster wheel, I know some of my others cars have so you can lower the beam when the back is full, wonder if that would be the case here, guessing the Range is far too clever to need something like that? Formerly happymadison1978
Post #657457 22nd Feb 2023 4:20pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
BMW electronics fitted at that age will have an integrated rain/light sensor, but that only controls the lights' automatic illumination and extinguishing points. If the lights are physically low it's most likely either the height adjuster is set low, the lights are out of adjustment, or the adjusters in the lamp units themselves have broken. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #657460 22nd Feb 2023 4:34pm
