Home > Maintenance & Mods (L322) > Is this the sound of a Brake Shield Catching?
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
When travelling down a local country lane, when the camber of the road changes, where the road dips at one side, it's making a noise at the rear O/S wheel. My local indy was unable to identify it and while at the local MD nothing was falgged on their health check.
I'm not very technical, but I'm beginning to wonder, could this intermittent noise be caused by a brake shield catching against the disc?
I can't see any evidence of rubbing, but it's not easy to inspect.
Please see video clip below and let me know your thoughts:
Post #656492 13th Feb 2023 3:50pm
is it the same when you reverse?
kinda think its a jack up and rotate wheel, or/and take the wheel off. ... - .- -.
Post #656494 13th Feb 2023 4:07pm
aja500
I've not tried that Stan, will test and let you know Thumbs Up
Post #656495 13th Feb 2023 4:10pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
I would go for rear shoes can you see the pins that hold the shoes in place on the back plate has one let go new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #656498 13th Feb 2023 4:27pm
mjdronfield
The brake shields tend to rust through where they bolt on then come unfastened and rattle about. That doesn’t sound like a rattle so I’d try what’s been mentioned already… handbrake shoes etc…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #656502 13th Feb 2023 4:44pm
aja500
I've had a look Oggy but I can't really tell, and to be honest, I'm not really sure what I'm looking for.
I haven't tried reverse yet, as I need to drive somewhere where the road surface changes, but what I can say, is that it only makes this noise when the road surface dips / has some subsidence. It's slightly worse with a combination of uneven surface and when cornering occurs but fine driving normally on a level surface.
Post #656503 13th Feb 2023 4:50pm
aja500
Thanks MJ Dronfield - I'd say definitely not a rattle, more an intermittent scraping sound.
Post #656504 13th Feb 2023 4:52pm
Merchy
Besides checking things mentioned in above posts, the sound could also be a bent / loose heat shield or section of exhaust, jack it up and have a look when inspecting the brakes etc.
Post #656516 13th Feb 2023 6:33pm
aja500
Apologies all for the slow response, I've been up in Yorkshire this week.
Thank you all for taking the time to reply.
Firstly Stan, thanks for your question, oddly, no it doesn't seem to make the noise when in reverse. However, I don't know if this could be linked or not, but I did notice yesterday when reversing down hill on my driveway that the brakes squeaked, something it doesn't do at all while moving forward. I don't know if all this suggests anything or not?
Thank you also to Merchy, oggy and mjdronfield for your suggestions, the general consensus seems to be that it's either brake shoes or something catching. I'll get these all checked out Thumbs Up Thumbs Up
Post #657111 19th Feb 2023 8:27am
Rudyard1
I had the same - I stuck my hands through the wheels and pushed the brake shield back a bit - quite hard to do and depends on style of wheels/size of hands! Seems to have worked.
I do need to replace my brake shields as they hold the park brake shoes - it is so corroded it isn’t holding the pins for the shoes themselves. Does look like a pig of a job.
Post #657133 19th Feb 2023 2:51pm
aja500
Thanks Rudyard1, will have a look at that Thumbs Up
Post #657166 19th Feb 2023 9:56pm
