![]() | Home > Maintenance & Mods (L322) > Is this the sound of a Brake Shield Catching? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
is it the same when you reverse?
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 ![]() ![]() ![]() |
I've not tried that Stan, will test and let you know |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
I would go for rear shoes can you see the pins that hold the shoes in place on the back plate has one let go new vehicle purchase
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
The brake shields tend to rust through where they bolt on then come unfastened and rattle about. That doesn’t sound like a rattle so I’d try what’s been mentioned already… handbrake shoes etc…..
I've had a look Oggy but I can't really tell, and to be honest, I'm not really sure what I'm looking for.
Thanks MJ Dronfield - I'd say definitely not a rattle, more an intermittent scraping sound. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1223 ![]() ![]() ![]() |
Besides checking things mentioned in above posts, the sound could also be a bent / loose heat shield or section of exhaust, jack it up and have a look when inspecting the brakes etc. |
Apologies all for the slow response, I've been up in Yorkshire this week.
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 86 ![]() ![]() |
I had the same - I stuck my hands through the wheels and pushed the brake shield back a bit - quite hard to do and depends on style of wheels/size of hands! Seems to have worked.
Thanks Rudyard1, will have a look at that |
