Home > In Car Electronics (L322) > My radio/screen etc keeps cutting out and restarting.
DaveAbbott
Guys
My L322 (09) radio/screen keeps cutting out and restarting.
Functions work when its on but afetr a minutes it goers dead and almost immediately restarts.
Just seen a Ytube video of another person who has the same isssue - but I cannot find a solution
I have tried the MOST by pass , no change.
Any suggestions please, driving me mad.
Dave
Post #656013 8th Feb 2023 9:20am
garyRR
Sounds like it could be as simple as a grounding issue or loose plug on the head unit, both of which are well-known problems on these cars.
Start with taking the unit out for a look at the plugs.
Then start looking at grounding points. The easiest to access I can think of is passenger side footwell behind the interior wheel arch trim. 2015 Range Rover Autobiography 4.4 SDV8
Post #656016 8th Feb 2023 9:53am
DaveAbbott
Hi Gary
Thanks for your response, however I have rulerd out a simple power connectivity issue, as this is very rythmic in timing
and the orange flashing light still shows when the screen dies. A loose connection would be more random?
But I will investigate your idea.
Dave
Post #656019 8th Feb 2023 10:28am
Stuart-
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Are you getting any random warning lights at the same time? If so, that's how this saga of mine started. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #656028 8th Feb 2023 12:14pm
DaveAbbott
Hi Stuart.
Absolutely clear of warning lights - no other symptoms whatsoever.
Voltage checked on tick over at 14.0
Screen is live for about a minute, then crashes , in whatever mode I am in at the time and then restarts without any prompting from me a few seconds later
Regards
Dave
Post #656066 8th Feb 2023 6:09pm
DaveAbbott
Please help
Is there anyone out there who knows what causes this to switch on anf off all the time.
Did the self testing bit yesterday, and of course nothing shows as it is working wehilst I am able to do the test, tehn it switches off and comes back on again with the LR screen
Round and round we go
Please help
Dave
Post #656085 9th Feb 2023 9:07am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
It would appear that mine has started doing the exact same thing. It was fine on the previous journey, now it seems to cut out and restart rythmically, but about every 5 seconds unlike Dave's which times in minutes. Reverse camera works fine with no cutting out.
Any pointers would be very much appreciated. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #666063 7th Jun 2023 7:52am
DaveAbbott
Radio etc cutting out
Mine was cuting out every 30 secs or so.
A Hard Reset cured it.
Worth a try.
Dave
Post #666064 7th Jun 2023 8:05am
rvbush
By hard reset do you mean disconnect battery and join +ve to -ve? Thanks. Drives:
Post #666112 7th Jun 2023 1:50pm
rvbush
Well, went out in the car just now and in true Fatty fashion it seems to have forgotten it had a fault and all is working again. We'll see how long that lasts! Drives:
Post #666155 8th Jun 2023 9:30am
this voodoo thing does happen a lot with these vehicles.. Thumbs Up ... - .- -.
Post #666164 8th Jun 2023 10:43am
daveturbo
Audio Issues
Im having the exact same Fault,not sure to try replacing the rear audio Amp. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #673898 20th Sep 2023 10:52am
rvbush
I found mine was due to a dud bluetooth module. Replaced and all was well for a few months, now it's started doing it again. I'll replace the bluetooth again, but if it happens any more then it could be something else making the bluetooth module fail. Drives:
Post #673909 20th Sep 2023 1:17pm
