![]() | Home > In Car Electronics (L322) > My radio/screen etc keeps cutting out and restarting. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Sounds like it could be as simple as a grounding issue or loose plug on the head unit, both of which are well-known problems on these cars.
DaveAbbott Member Since: 09 Jan 2023 Location: Soham Posts: 14 ![]() ![]() |
Hi Gary
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 367 ![]() ![]() ![]() |
Are you getting any random warning lights at the same time? If so, that's how this saga of mine started. 2017 4.4 SDV8 Autobiography in black
Hi Stuart.
Is there anyone out there who knows what causes this to switch on anf off all the time.
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
It would appear that mine has started doing the exact same thing. It was fine on the previous journey, now it seems to cut out and restart rythmically, but about every 5 seconds unlike Dave's which times in minutes. Reverse camera works fine with no cutting out.
Mine was cuting out every 30 secs or so.
By hard reset do you mean disconnect battery and join +ve to -ve? Thanks. Drives:
Well, went out in the car just now and in true Fatty fashion it seems to have forgotten it had a fault and all is working again. We'll see how long that lasts! Drives:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35627 ![]() ![]() |
this voodoo thing does happen a lot with these vehicles.. |
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 ![]() ![]() ![]() |
Im having the exact same Fault,not sure to try replacing the rear audio Amp. Mercedes AMG w207
I found mine was due to a dud bluetooth module. Replaced and all was well for a few months, now it's started doing it again. I'll replace the bluetooth again, but if it happens any more then it could be something else making the bluetooth module fail. Drives:
