![]() | Home > Maintenance & Mods (L405) > SMOKE & FUMES STILL after oil cooler changed!!… |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
So I pulled fuse today for FBH 90 mile trip and no fumes or smoke is this coincidental or has my issue been the FBH all along as smell was always stronger outside car on driver side by tyre makes sense as FBH exhaust is behind wheel arch liner apparently. I will monitor for next few days and if it turns out to be the FBH is it a case of replacement or something else with the FBH causing it to omit really bad fines into cabin and smoke up into back of engine. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 ![]() ![]() |
Is there not a modification for the exhaust/intake for the FBH. As the intake on my 2017 is different to my 2014 and I used to always get fumes inside with the 2014 when FBH was used which I don't seem to now on the 2017.
Hi was this mod a recall? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Not sure. 2004 4.2 SC Japan Spec
Just to add also still got the FBH fuse unplugged and no fumes in cabin or around outside car and no smoke at back of engine area will monitor over weekend hopefully this was the issue the oil cooler still needed doing as there was a leak just convenient about smells etc and possibly the FBH Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 233 ![]() ![]() |
The black canisters in the photo are related to fume emission control on the petrol models only. (LR076037 Cannister - Fuel Vapour Store). Connects to the FBH air inlet. Last edited by Fifth Horseman on 17th Mar 2023 12:29pm. Edited 1 time in total |
Well FBH fuse made no difference fumes this evening again!! Loads of smoke from back of engine seems to be intermittent only when I give the car some revs which I did this evening. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
I must say aswell fumes and smoke are only when I give the car some stick eg sport mode high revs and only when the engine has warmed up no fumes or smoke when engine is cold. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 142 ![]() ![]() ![]() |
I had my oil cooler replaced recently after finding the back of the engine was drenched in oil when I took the shield off. Just after the cooler was replaced I'd get puffs of smoke appear from the around the sides of the bonnet. Thick smoke. I asked the garage that did the work what this was about as there hadn't been these plumes of smoke before and they told me it is common the have oil pool after the cooler is replaced and that it'd only last a short while.
Yeah the garage that changed my oil cooler said the same to me that back of my engine was covered but the smoke was coming from oil hitting hot exhaust near it. I thought it would of cleared within a few weeks of daily driving 80 miles round trip but I still have fumes and smoke intermittently. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Hi guys really have hit a brick wall STILL having smoke and horrible fumes which is ONLY intermittent mainly when car hot but that said did a 300 miles roundtrip recently and nothing no smoke or fumes etc... had 2 garages look at it don't know where its coimg from oil cooler done all good o ring on pipe done at back of oil cooler and I been monitering there's no oil on floor driveway etc! surely this oil wouldn't take 4 weeks to burn away from back of engine doesn't it only smoke as the oil hits the exhaust as this gets hot? Any other ideas what's causing these disgusting fumes and smoke at back of engine. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Geo Member Since: 04 Apr 2023 Location: South East Posts: 16 ![]() ![]() |
I had similar after oil cooler change at MD.
Marcel M6 Member Since: 15 Jun 2021 Location: Hertfordshire Posts: 19 ![]() ![]() ![]() |
Quite a few of us waiting for that part - earliest I've seen quoted for availability is end May! |
