Home > Maintenance & Mods (L405) > SMOKE & FUMES STILL after oil cooler changed!!… |
Geo Member Since: 04 Apr 2023 Location: South East Posts: 16 |
Glad to hear you got it sorted Jay, an independent solution is often the best way.
6th Apr 2023 3:16pm |
Out of interest are you still running the RR as a daily? Any issues cropping up (beyond topping up).
6th Apr 2023 3:19pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 295 |
Hi Geo I am running it daily yes about 50 miles a day so obviously the smoke and fumes I am still getting can not be related to excess oil still burning off from oil cooler change as this should of all well burnt off by now. I am not losing any coolant so we have no idea where the smoke is coming from and its intermittent which is the annoying thing! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
8th Apr 2023 12:10pm |
Agree it’s the intermittent stuff that is most tricky. Good luck sorting it. |
11th Apr 2023 1:46pm |
Explored every avenue trying to get to bottom of this intermittent smoke at back of engine and fumes oil cooler changed o rings changed at turbo feed pipe all pipes checked around donut jubilee clips all good no split pipes etc... any more ideas anybody. We did notice a small amount of oil around turbo nothing major possibly an oil leak from turbo could be culprit when its hot causing smoke fumes.
21st Apr 2023 9:22am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4305 |
Has James Henhsall at Henshall Engineering taken a look at it for you? He's very good and in Cheshire hence the recommendation. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
21st Apr 2023 12:32pm |
Hi @Drrob thanks for this I will contact James next week fingers crossed. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
21st Apr 2023 3:46pm |
RRL405 Member Since: 21 Feb 2024 Location: Athens Posts: 3 |
Hey Jay,
21st Feb 2024 4:39pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 187 |
How is your coolant level, is it staying stable or has it dropped? Current yokes
21st Feb 2024 9:01pm |
Well its been in for the typical oil change and I have not checked since. But the smoke is more of a burnt oil smelling smoke. What ideas do you have about the coolant? Also the smoke comes from the part of the engine that is against the firewall, are there any coolant lines back there? |
21st Feb 2024 9:26pm |
Hi this really is a strange one I had no more smoke and fumes due months then suddenly got that dreaded smell on cabin again don’t know whether it was a coincidence but I’m sure the car was doing a DPF regen so I am now going down this avenue of investigation. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
21st Feb 2024 9:55pm |
But if it smokes that often, every few rides or every ride is it normal to do a DPF regen that often too?
22nd Feb 2024 7:02am |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 333 |
Jay,
22nd Feb 2024 11:58am |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 131 |
When I had my leaking oil cooler replaced, straight after and quite randomly there would be mysterious plumes of grey smoke appear out from under the bonnet. It didn't seem to be related to engine incline or even movement, I was sat at the lights and a lot of grey smoke belched out around the bonnet.
22nd Feb 2024 2:03pm |
