![]() | Home > In Car Electronics (L405) > 3 data sim not supported |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
This probably isn't much help but my 3 data SIM worked fine out the packet without any activation etc. It said 12 months but actually lasted 2 years before it cut off. Second one installed in December was the same.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1310 ![]() ![]() |
Find someone who can test the data sim in their phone.
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 508 ![]() ![]() ![]() |
Thanks for your replies, I think it is in the correct way, contacts towards the fronton the car and the notch uppermost.
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 800 ![]() ![]() |
Hopefully the replacement will work. I've had 2 in mine (12 month and now 24 month) and did have the same issue with the first one, but taking it out and carefully inserting it (used some tweezers) did the trick. The second one was fine.
Cheers folks, I'll carefully put the old one back in until the new one arrives and see what happens. 👍🤞 First time FFRR owner |
ordered a new sim and that doesnt work either. Will go into a 3 shop and see if something needs doing to the card before it will work First time FFRR owner |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1657 ![]() ![]() ![]() |
Hi Arch,
No offence taken there Gremlin, that is always a good start point to go back to very basics. Unfortunately I went with 3 as my mobile is with them and I get 5g coverage and the ca is saying SIM not supported, rather than no signal.
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
I don’t think a 5g SiM will work in the LR and I think all new 3 Sims are 5g capable 4.2 SC - sold , now bought back
I'm not sure the SIM (subscriber identity module) has any bearing upon the speed of the carrier other than being enabled or not for various connectivity types, they should all fall back to (ultimately) 2G if higher speeds are not available.
Update,
Have you tried either sim in another device? - despite what the teenagers in 3 say, I think it does at least need to connect to a network to initialise first. |
yeah they connected it to a phone in the shop and used it.
Well if its been initialised in a phone, then it should work OK. Can you see any DTC's set? |
