Home > Technical (L322) > Bonnet Insulators - What do they do?
Epson Green
These foam rubber insulators on my 2012 Westie have started to crumble and absorb a lot of water.
Am I ok to just remove them?
 Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #654815 26th Jan 2023 7:48pm
mjdronfield
I think they are supposed to reduce noise.
Plenty of folk have removed them without issue.
No idea how much new ones are though.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #654818 26th Jan 2023 8:04pm
Epson Green
Many thanks, I thought they may be blocking a noise path. It looks like the are about £20 each, but if they hold water I would sooner do without them Kevin
Post #654819 26th Jan 2023 8:10pm
mjdronfield
I’d imagine yours are the original ones, so may be a good 8 odd years before new ones have the same issue?
See if there is more noise without them and decide whether you need them.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #654824 26th Jan 2023 9:25pm
DrRob
Remove and bin them.
They serve Censored all purpose apart from trapping water and mud risking rust.
Stupid design Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #654827 26th Jan 2023 9:59pm
JayGee
Removed mine with no ill effect. 2012 TDV8 Vogue (L322)
Post #654850 27th Jan 2023 9:34am
A1GSS
Coincidentally I posted a near-identical Q on the RRS forum a couple of days ago! Same consensus. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #654853 27th Jan 2023 10:41am
Epson Green
Thank you for confirming what I thought - they have been binned👍👍 Kevin
Post #654859 27th Jan 2023 11:26am
DrRob
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #654949 28th Jan 2023 10:20am
these pads are designed to reduce wind noise..and yes if you get them wet and then have a freeze then its very difficult to open the bonnet cos they stick to it..
https://www.fullfatrr.com/forum/topic31520.html
https://www.fullfatrr.com/forum/topic49951.html?highlight=foam ... - .- -.
Post #654957 28th Jan 2023 12:36pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Part of my nearside one fell off the other day. After this thread I'll take off what's left on both sides and consign them to the bin. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #654961 28th Jan 2023 2:34pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
There was some discussion of something like these on the L322 owners FB group a few days ago. The suggestion was that they direct draining water toward the drains and stop it pooling and then getting into the front door hinge mechanisms. The pads being referred to, as far as I could determine, seemed to be under the bonnet and underneath the bottom of the A-pillars so it may be different ones. I’ll have a look on my 2012 next time the bonnets up and see what’s actually there.
I wonder if anyone whose binned these has had water ingress issues into the front doors ? TDV8 4.4 2012
Post #655029 29th Jan 2023 8:35am
kevinp
Interesting you say that Ramblin Man. When I open my front near side door after washing or rain, I get a constant fine dribble of water that lasts for about a minute from the corner of the door seal.
I just presumed it was going down the window seal.
Post #655035 29th Jan 2023 9:58am
mjdronfield
That’s why I figured that for what they cost, might as well put new ones in. They obviously do something, maybe in addition to noise suppression.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #655058 29th Jan 2023 2:30pm
