Home > Technical (L322) > Bonnet Insulators - What do they do? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
I think they are supposed to reduce noise.
26th Jan 2023 7:04pm |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 112 |
Many thanks, I thought they may be blocking a noise path. It looks like the are about £20 each, but if they hold water I would sooner do without them Kevin
26th Jan 2023 7:10pm |
I’d imagine yours are the original ones, so may be a good 8 odd years before new ones have the same issue?
26th Jan 2023 8:25pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Remove and bin them.
26th Jan 2023 8:59pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3237 |
Removed mine with no ill effect. 2012 TDV8 Vogue (L322) |
27th Jan 2023 8:34am |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Coincidentally I posted a near-identical Q on the RRS forum a couple of days ago! Same consensus. Graham
27th Jan 2023 9:41am |
Thank you for confirming what I thought - they have been binned👍👍 Kevin
27th Jan 2023 10:26am |
Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
28th Jan 2023 9:20am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35329 |
these pads are designed to reduce wind noise..and yes if you get them wet and then have a freeze then its very difficult to open the bonnet cos they stick to it..
28th Jan 2023 11:36am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
Part of my nearside one fell off the other day. After this thread I'll take off what's left on both sides and consign them to the bin. 2017 5.0 Autobiography Supercharged
28th Jan 2023 1:34pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 276 |
There was some discussion of something like these on the L322 owners FB group a few days ago. The suggestion was that they direct draining water toward the drains and stop it pooling and then getting into the front door hinge mechanisms. The pads being referred to, as far as I could determine, seemed to be under the bonnet and underneath the bottom of the A-pillars so it may be different ones. I’ll have a look on my 2012 next time the bonnets up and see what’s actually there.
29th Jan 2023 7:35am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1215 |
Interesting you say that Ramblin Man. When I open my front near side door after washing or rain, I get a constant fine dribble of water that lasts for about a minute from the corner of the door seal.
29th Jan 2023 8:58am |
That’s why I figured that for what they cost, might as well put new ones in. They obviously do something, maybe in addition to noise suppression.
29th Jan 2023 1:30pm |
