![]() | Home > Technical (L405) > Loss of medium speed CAN network. |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
Do the faults come back when cleared? Dan. 🇨🇦 2013 L405 5.0 SCV8 |
The MS-CAN is capable of operating 'one legged' so its unlikely to be a wiring issue unless there is already one leg down. Can you list all U codes on the vehicle please?
harryboy Member Since: 21 Jan 2023 Location: UK Posts: 10 ![]() |
Hello thank you for your reply. It is the same 2 codes listed for all of those modules in the pictures. Do you know if there are any other modules on the MS-CAN network other than the ones in my pictures? As then maybe there's a problem with that one like you say and I can investigate it. I couldn't find a list of all the modules on the MS-CAN but maybe you can see one missing off my list? When the MS can network is down i can't scan or pick codes up on any of the pictured modules, but these codes will be stored when the network is back online. |
Another thing to mention is when the CAN system goes down. I can not lock the car from the key. I also can not start the car as it says smartkey not found.
Well thats a big clue right there, the diagnostic socket connects to MS-CAN by splices between the KVM module and the instrument pack, can you see anything on HS-CAN when you lose communication on the MS-CAN? Is there any indication of activity on the instrument pack? KVM is clearly losing comms to the instrument pack so I'd start there but first, with the battery disconnected, can you take a resistance measurement across pins 3 & 11 of the diagnostic socket, it should be 60Ohms, if it is anything else, that indicates a physical problem. Also bear in mind that I'm working from 'old knowledge' - I don't have wiring diagrams to hand for your age of vehicle so it's possible that the gateway module replaced the functions of the instrument pack with regard to the MS-CAN. I'll see if I can find the correct wiring diagram but I no longer have unfettered access to Topix... |
Thank you again Phoenix for your help, I really do appreciate it.
Right, found the diagram (it's in the Wiki as part of the workshop manual) attached below.
Thanks again, we are getting somewhere on this.
The deployable side steps / running boards shouldn't be an issue if you've disconnected the control module, I've never known CAN of any speed to not recover (sometimes after a couple of ignition / power cycles) once the source of disruption is removed. I'm not sure if the GWM is a 'one shot' device, when I worked for a LR dealer, we did change a few but they were always new (obviously), maybe contact GAP first to see what their procedure is for re-coding. The KVM is, without a doubt, a one-shot device, if you add a trailer module you have to replace the KVM.
There was once something related to the electronic steering rack with a code improper shutdown? But I don't think this is relevant to anything as it only happened once or twice and I put it down to the very low voltage and there were a host of other DTCs.
Thanks - nothing on the vehicle should suffer an 'improper shutdown' with system voltage above 11VDC, yes, you'll get low voltage warnings but everything should still work or at least communicate down to 10.5VDC and sporadically beyond.
Will do, thanks again for your help. Will report back when I have some new findings. |
pasha0305 Member Since: 09 Mar 2024 Location: London Posts: 10 ![]() ![]() ![]() |
Sorry for restarting an older thread. Just would like to know if you managed to solve the issue? 2016 TDV6 Vogue SE Santorinin Black |
