Home > Technical (L405) > Loss of medium speed CAN network.
harryboy
Hello all, I’d be grateful for some help on this.
2014 4.4 sdv8
Started off with the car not locking, and unable to start as key not recognised.
Intermittent fault.
Seem to be loosing all medium speed CAN network. Can happen when driving and things like auto high beam assist stop working as I notice the high beam assist auto light disappear of the instrument cluster. Also the parking aid stops working. - these are all modules on the med speed can network.
Also notice alternator stops charging battery but unsure if this is an issue with the alternator or something related to the gateway module and CAN system stopping the alternator from charging.
These are the codes.
I changed the two batteries which seemed to make the problem disappear for a day or two, now it’s back.
Occasionally also get charging fault.
I’ve removed drivers seat and inspected wiring here, appears ok.
Thinking of changing the alternator next but it’s a bit of a job so unsure whether to commit if it doesn’t solve anything.
Thanks in advance for your help.
Post #654772 26th Jan 2023 1:33pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Do the faults come back when cleared? Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #654784 26th Jan 2023 4:13pm
Phoenix
The MS-CAN is capable of operating 'one legged' so its unlikely to be a wiring issue unless there is already one leg down. Can you list all U codes on the vehicle please?
Are there any modules on that network that are not reporting any DTC's?
It's possible that there is a module shutting down that is a pass through and interrupting the flow of messages. The alternator will not be connected other than the ECM not receiving data from the ATCU so the charge strategy will be affected, a symptom not a cause.
Post #654787 26th Jan 2023 4:23pm
harryboy
Hello thank you for your reply.
It is the same 2 codes listed for all of those modules in the pictures.
Do you know if there are any other modules on the MS-CAN network other than the ones in my pictures? As then maybe there's a problem with that one like you say and I can investigate it.
I couldn't find a list of all the modules on the MS-CAN but maybe you can see one missing off my list?
When the MS can network is down i can't scan or pick codes up on any of the pictured modules, but these codes will be stored when the network is back online.
Post #654793 26th Jan 2023 5:17pm
harryboy
Another thing to mention is when the CAN system goes down. I can not lock the car from the key. I also can not start the car as it says smartkey not found.
Many thanks.
Post #654803 26th Jan 2023 6:25pm
Phoenix
Well thats a big clue right there, the diagnostic socket connects to MS-CAN by splices between the KVM module and the instrument pack, can you see anything on HS-CAN when you lose communication on the MS-CAN?
Is there any indication of activity on the instrument pack?
KVM is clearly losing comms to the instrument pack so I'd start there but first, with the battery disconnected, can you take a resistance measurement across pins 3 & 11 of the diagnostic socket, it should be 60Ohms, if it is anything else, that indicates a physical problem.
Also bear in mind that I'm working from 'old knowledge' - I don't have wiring diagrams to hand for your age of vehicle so it's possible that the gateway module replaced the functions of the instrument pack with regard to the MS-CAN.
I'll see if I can find the correct wiring diagram but I no longer have unfettered access to Topix...
Post #654817 26th Jan 2023 8:00pm
harryboy
Thank you again Phoenix for your help, I really do appreciate it.
The HS-CAN system works entirely without fault when the car goes in to MS-Can tantrum mode.
There aren't even any warnings on the dash in tantrum mode other than I notice things like the Auto high beam assist, park sensors, can't lock the car, can't start car unless key held to column. And then eventually the battery charging system or low battery fault will come on. Instruments etc. all work fine. Car drives fine other than steering feels heavy, wipers go slow as the battery voltage drops from 14.4 down to around 12.
It's weird because the car works absolutely fine for a day or two with the new batteries or when I fully charge the battery.
Went out and measured the resistance and it was 62-64 so I'm guessing bang on.
Another thing to note is there was a lot of rain the week the car started having the issues; but i'm not sure if this is just a coincidence or if there are some common places water may have got in from puddles etc.
The frustrating thing is i'm sure this is something simple, it's just diagnosing it seems to be a problem. I don't have any facility to connect to the MS-Can and diagnose this way; but i'm guessing this would reveal the issues? Would a local Indy have this facility or is it delaer only.
Also my other thoughts were maybe the alternator is becoming intermittent and thus battery voltage is dropping and causing issues on the MS CAN network? Just find it strange that the car seems fine when the batteries are fully charged up as if they are masking something.
Thank you again for taking the time to help me Smile
Post #654821 26th Jan 2023 8:23pm
Phoenix
Right, found the diagram (it's in the Wiki as part of the workshop manual) attached below.
Firstly, you need to identify what modules you have installed, if the HS-CAN is staying up then there's a good chance the Gateway module is OK, I'm now re-evaluating the voltage issue as it shouldn't go that low just with lost comms. It is of course possible that the Gateway module is faulting or losing power, it directly connects to the alternator and the BMS so given your issues, it's the most likely culprit at this stage. If you can, get access to it and check the connectors for security, damage, corrosion and if you can get hold of appropriate test pins, pin grip.
None of the above should be prohibitive for an indy that isn't 'afraid' of communication issues, it's just basic electrical diagnostics (and to be fair, not all dealer techs are entirely comfortable with it either, but they at least have, or should have, a trained and experienced Diag / master tech to take over.) If you have the time and confidence, it's nothing that can't be done yourself with a minimum of reliable test equipment.
https://www.fullfatrr.com/gallery/albums/u...ody%20.pdf
ETA - battery voltage would have to be below 10.5VDC, you would also get low voltage DTC's detected on other systems.
It's also important to realise the difference between DTC's for missing messages and 'bus off', the former indicates a module has not received an expected message from another module, whereas the latter indicates collisions (on the network!) detected or other conditions that are preventing communication (shorts to +ve or -ve, malformed packets etc.).
Given that the CJB & GWM are the end of line modules, you can unplug any other module on the MS-CAN without disrupting the integrity of the network, the EOL modules are the only ones reporting 'bus off', it is possible that another module is spamming the network - unplugging them would reduce functionality but should prove network hardware resilience...
I keep coming back to the charging and lighting issues though, both of which use the GWM....
Apologies for the ramblings - I'm just working through the wiring diagram, the door modules and wiring through the door harness flex connector could be a source of the problem, you could try opening and closing the doors and manipulating the harness in the rubber boot to see if it provokes a response - the same goes for the upper tailgate flex connections, again though, that shouldn't cause the GWM to inhibit basic functions just because it turns off the MS-CAN.
Just noticed there is a fault showing in the PCM in one of the above photos - what is it please?
Post #654822 26th Jan 2023 8:45pm
harryboy
Thanks again, we are getting somewhere on this.
Correct; HS-Can is staying up without fault.
My car does appear to have most of those modules on your wiring diagram. Something which may be of note, someone has removed the running boards/side-steps at some point and left the connectors dangling by the cills. They were corroded and short circuiting and full of mud. I just disconnected the entire running board module in the boot (early on in my testing as I initially suspected this could be the issue?). However it made no difference. Do you think this may have caused some irreversible damage to something?
Well my next course of action will be to inspect the GWM and see if there's anything obvious going on. Would it be worth buying a second hand one of a car with similar spec to see if it works?
With the whole network going down am I correct in thinking that the problem is either the GWM or the junction box - central? (just to check, is this the fuse box behind the dash?) As they have the terminating resistors?
The weird thing is on my initial fault codes Parking Aid is on the HSCAN but this fails and stops working when the car goes in to tantrum mode and then will work again when the car is normal Not sure what relevance this has...
I can't thank you enough for taking the time to help! You're probably bored of hearing it haha.
Post #654828 26th Jan 2023 10:08pm
Phoenix
The deployable side steps / running boards shouldn't be an issue if you've disconnected the control module, I've never known CAN of any speed to not recover (sometimes after a couple of ignition / power cycles) once the source of disruption is removed. I'm not sure if the GWM is a 'one shot' device, when I worked for a LR dealer, we did change a few but they were always new (obviously), maybe contact GAP first to see what their procedure is for re-coding. The KVM is, without a doubt, a one-shot device, if you add a trailer module you have to replace the KVM.
Yes, the CJB is the one behind the dash, with fuses & relays, next time the MS-CAN fails, can you measure the supply voltage at one of the modules, other than the CJB or GWM, it'd be best to expose one of them ahead of time so you can check the voltage with the minimum of fuss. The terminating resistors primary function is to stop 'reflections' on the network but also gives the ability to test network integrity, I've never known them to go 'bus off' just because they're EOL devices. It is possible that there is some powersaving mode that shuts off the devices on MS-CAN - but - there should be DTC's for low voltage / powersave initiation...
Without being 'hands on', I'd suggest checking the GWM more closely, one more question - does the system voltage drop before the loss of MS-CAN or after?
Post #654833 26th Jan 2023 10:30pm
harryboy
There was once something related to the electronic steering rack with a code improper shutdown? But I don't think this is relevant to anything as it only happened once or twice and I put it down to the very low voltage and there were a host of other DTCs.
Yes I'll check the voltage at one of the modules such as the drivers door module (assuming I check it whilst module is plugged in?)
I'll have a look at the GWM and see if there's anything obvious. I'll also have a look at the CJB to check this and the fuses.
I can't answer the last question accurately but I shall check it and see next time.
Post #654838 26th Jan 2023 10:53pm
Phoenix
Thanks - nothing on the vehicle should suffer an 'improper shutdown' with system voltage above 11VDC, yes, you'll get low voltage warnings but everything should still work or at least communicate down to 10.5VDC and sporadically beyond.
Body system module voltage can be checked open circuit but is always better whilst connected - back probing the connector is better than potentially opening up the receptacles in the housing anyway.
Not wanting to teach any egg-sucking, when checking the modules, use all your senses and note anything unusual in the general area, don't just focus on the modules themselves. For example, look for condensation in the vicinity, listen for any relays activating or contacts arcing, check for localised heat or any 'hot electrics' smell along with the more obvious water dripping out of the module when moved or green connector pins / corroded screws.
Post #654840 26th Jan 2023 11:08pm
harryboy
Will do, thanks again for your help. Will report back when I have some new findings.
Post #654843 26th Jan 2023 11:49pm
pasha0305
United Kingdom 2016 Range Rover Vogue SE TDV6 Santorini Black
Sorry for restarting an older thread. Just would like to know if you managed to solve the issue? 2016 TDV6 Vogue SE Santorinin Black
Post #707321 21st Dec 2024 12:29am
