Home > Maintenance & Mods (L322) > Washer jet upgrade - fan pattern jets
Phoenix
They were fine on the donor car, so it's unlikely they're blocked / restricted, the additional pump is only £8 so if it works or not, it's hardly breaking the bank. The LR pump part number doesn't change until L405 so there should be no difference in early/late L322's.
Post #655986 7th Feb 2023 11:11pm
JayGee
I don't have any issues with the standard setup to be honest. The rear is another matter and a spray rather than jets would be a lot better but as the nozzles are integrated into the arm this would be hard to implement. 2012 TDV8 Vogue (L322)
Post #656012 8th Feb 2023 10:09am
Phoenix
Yep, the standard ones are 'fine', the fan spray are 'better', I suppose I'm in a position where I can experiment for no, or low cost on a lot of changes. If improving the pressure gets to be too much hassle or costly, then I can easily revert to standard.
Post #656039 8th Feb 2023 3:35pm
