Home > Maintenance & Mods (L405) > Jacking up a 2019 L405 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8330 |
You can open a door to stop the suspension from dropping or raising but it won't stop gravity dropping the wheel you are trying to jack...
16th Jan 2023 8:46pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35427 |
same, leave the door/tailgate open.. ... - .- -.
16th Jan 2023 8:47pm |
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 |
OK thanks, I'll try the tailgate/door thing tomorrow.
16th Jan 2023 8:51pm |
No, as I said, nothing will stop the wheel you are jacking up from dropping when you jack up the fatty, gravity takes over...!!
16th Jan 2023 8:54pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1536 |
-or get a higher lift jack! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
16th Jan 2023 9:33pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1151 |
Is it not possible to trolley jack the car in locked access mode? This way the car is lower. overfinch modified |
17th Jan 2023 10:06am |
I was hoping there was a way of locking the suspension...
17th Jan 2023 11:14am |
There is NO WAY to lock the suspension when you jack it up unless you have an anti gravity machine... Pete
17th Jan 2023 11:52am |
before you go and bang your head again Pete, this is an extract from the owners manual,
17th Jan 2023 12:17pm |
Stan,
17th Jan 2023 12:30pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7958 |
Isn't that required for the next steps - removing the spare wheel I've tried all sorts, opening doors, boot, hazards on etc. and not found it makes any difference. Has anyone actually tried & measured a difference ? |
17th Jan 2023 3:43pm |
Does anyone know why it should not be jacked in low mode> I,m sure I have seen a Youtube video jacking the car in low mode.
17th Jan 2023 3:45pm |
17th Jan 2023 3:56pm |
Low mode... high mode, makes no difference to how high you have to jack it, on low made you just jack it more... Pete
17th Jan 2023 4:47pm |
