![]() | Home > Maintenance & Mods (L322) > L322 rear LED conversion - question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35474 ![]() ![]() |
i dont think there is ....the wiki 'how to' on this uses the adaptor boxes..
Chlorothalonil Member Since: 08 Sep 2018 Location: East Yorkshire Posts: 53 ![]() ![]() ![]() |
Yeah, searched everywhere and can’t find the answer. |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
Did your car originally have two fogs? A lot of other cars just have the one on the “outside”.
Pretty sure it was both. Unfortunately I’ve sold the lights now, but I am 99.9% sure. I can live with that but it’s the flickering tail lights that aren’t good enough for me! |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
When I did my conversion I turned the hot (or cold - I can’t remember which) monitoring off using a Faultmate (I assume the IID tool will do the same) and it cured the problem. I didn’t use any resistors.
I’ve done that and it stops the weird flashing and indicator going too fast; just can’t find a way of keeping the fog light from coming on at low power with the circular tail lights. Someone must’ve solved this! |
John, does yours have the fog lights on when you switch your normal lights on? |
It did originally but then I changed the CCF coding. I was constantly being flashed by frustrated motorists…. Mine was the 2004.5 BMW so not the original launch spec but touchscreen / fibre optic model so I’m not sure if that made a difference?
