Home > Maintenance & Mods (L322) > L322 rear LED conversion - question
Chlorothalonil
United Kingdom 2008 Range Rover Vogue SE TDV8 Buckingham Blue
I have fitted the 2010 rear clusters to my 2008 model and found that everything works fine except the fog lights come on with the rear lights - the usual cure is the Powerful UK adaptor boards but since fitting those, the left fog has stopped working and the tail lights themselves have a slight flicker.
Might be a faulty board, but is there another way of solving the fog light issue without using the boards? Trying to find an auto electrician around here is difficult so I was wondering if there was something that I could do, as I am not too afraid to get involved in a bit of wiring.
Post #653637 15th Jan 2023 4:54pm
i dont think there is ....the wiki 'how to' on this uses the adaptor boxes..
you could do a forum search ,something might up.. ... - .- -.
Post #653643 15th Jan 2023 5:49pm
Chlorothalonil
Yeah, searched everywhere and can’t find the answer.
Post #653648 15th Jan 2023 6:42pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Did your car originally have two fogs? A lot of other cars just have the one on the “outside”.
Might be worth popping original lights back in and checking 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #653684 15th Jan 2023 11:38pm
Chlorothalonil
Pretty sure it was both. Unfortunately I’ve sold the lights now, but I am 99.9% sure. I can live with that but it’s the flickering tail lights that aren’t good enough for me!
Post #653685 15th Jan 2023 11:41pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
When I did my conversion I turned the hot (or cold - I can’t remember which) monitoring off using a Faultmate (I assume the IID tool will do the same) and it cured the problem. I didn’t use any resistors.
Regards
John
Post #653768 17th Jan 2023 12:40am
Chlorothalonil
I’ve done that and it stops the weird flashing and indicator going too fast; just can’t find a way of keeping the fog light from coming on at low power with the circular tail lights. Someone must’ve solved this!
Post #653769 17th Jan 2023 1:03am
Chlorothalonil
John, does yours have the fog lights on when you switch your normal lights on?
Post #653770 17th Jan 2023 1:04am
tb10
It did originally but then I changed the CCF coding. I was constantly being flashed by frustrated motorists…. Mine was the 2004.5 BMW so not the original launch spec but touchscreen / fibre optic model so I’m not sure if that made a difference?
Regards
John
Post #653849 17th Jan 2023 11:33pm
