Home > General > Pre-vent worked well |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
Hi. Is that feature available on all models or do you need to have the auxiliary heater option to cool the car down (I've seen somewhere on this forum that you can use the auxiliary heater to cool the car down when parked)? |
2nd Jul 2011 6:50pm |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 |
Hi there.
2nd Jul 2011 6:59pm |
Thank you for your prompt reply! Definitely a useful feature to have then, also in warm climates. |
2nd Jul 2011 7:09pm |
No probs. I imagine far more useful in St Tropez than GB!!! |
2nd Jul 2011 7:15pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
you can change the options on the remote control from heat to cold. when on heat the LED is red and green for cold. Current: TDV8 (3.6) RRS HSE
2nd Jul 2011 8:49pm |
dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014 |
I thought "Aux Vent" was standard on all cars (with the Nav Display)? Then if you had the heater it was "Aux Heating". |
3rd Jul 2011 12:59pm |
is there not the option to keep the heat/ventilation running after the engine has been switched off from one of the heater buttons, which is totally different to using the Webasto remote control to turn on the auxiliary heater/cold air blower.
3rd Jul 2011 5:10pm |
Yes, you are correct.
3rd Jul 2011 5:31pm |
