Home > General > Pre-vent worked well
johnson1
Hot day today. Wanted to try venting the cabin to see how it worked. Very impressed - cool (not cold mind) and still running when I got in the car. Ran for around 20 minutes without any low battery warnings.
Post #70910 2nd Jul 2011 3:44pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi. Is that feature available on all models or do you need to have the auxiliary heater option to cool the car down (I've seen somewhere on this forum that you can use the auxiliary heater to cool the car down when parked)?
Post #70924 2nd Jul 2011 6:50pm
johnson1
Hi there.
I have the Webasto FBH and it simply monitors the outside temp and decides whether to heat or vent. I used the remote to activate it. I also have the option to manually heat/vent in the timed climate section of the touch screen.
Post #70926 2nd Jul 2011 6:59pm
CSK
Thank you for your prompt reply! Definitely a useful feature to have then, also in warm climates.
Post #70930 2nd Jul 2011 7:09pm
johnson1
No probs. I imagine far more useful in St Tropez than GB!!!
Post #70931 2nd Jul 2011 7:15pm
stu
you can change the options on the remote control from heat to cold. when on heat the LED is red and green for cold. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #70940 2nd Jul 2011 8:49pm
dan_uk_1984
I thought "Aux Vent" was standard on all cars (with the Nav Display)? Then if you had the heater it was "Aux Heating".
Post #70974 3rd Jul 2011 12:59pm
stu
is there not the option to keep the heat/ventilation running after the engine has been switched off from one of the heater buttons, which is totally different to using the Webasto remote control to turn on the auxiliary heater/cold air blower.
excuse me if i am getting confused!! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71003 3rd Jul 2011 5:10pm
dan_uk_1984
Yes, you are correct.
The Keep Warm function uses the heat from the engine to keep the cabin warm for 30 minutes (great for if you're popping to the shops)
To activate you press "MAX A/C" upon exiting the car (with the key out of the ign)
This only works when the exterior temp is below 15C and if the engine is warm (I forget what is classed as warm - something like 75C)
Post #71009 3rd Jul 2011 5:31pm
