![]() | Home > General > Pre-vent worked well |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
Hi. Is that feature available on all models or do you need to have the auxiliary heater option to cool the car down (I've seen somewhere on this forum that you can use the auxiliary heater to cool the car down when parked)? |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
Hi there.
Thank you for your prompt reply! Definitely a useful feature to have then, also in warm climates. |
No probs. I imagine far more useful in St Tropez than GB!!! |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
you can change the options on the remote control from heat to cold. when on heat the LED is red and green for cold. Current: TDV8 (3.6) RRS HSE
I thought "Aux Vent" was standard on all cars (with the Nav Display)? Then if you had the heater it was "Aux Heating". |
is there not the option to keep the heat/ventilation running after the engine has been switched off from one of the heater buttons, which is totally different to using the Webasto remote control to turn on the auxiliary heater/cold air blower.
Yes, you are correct.
