Home > In Car Electronics (L322) > Car play or aux lead - 2006
toddo9
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Hi Guys,
New person here. I am picking up a 2006 RR Vogue SE at the weekend. I have never owed a RR before so this is pretty new to me.
I have been told that there is no AUX cable port and the interface is pretty basic.
Looking online and since signing up here, I see NAV tool (for Apple Car Play) is spoken about quite often however it is $500 for the part, plus I think you lose the NAV and it is tricky to install.
Another option I have seen that is much cheaper is a radio antenna splitter that puts out a signal on a frequency, this is all for around £100 and relatively easy to install however if someone near you tunes into that radio frequency they might hear you. This is essentially grabbing a signal from the charging port of your phone. I am unsure if it does calls (which is kind of more important).
I was wondering if anyone has had/or solved this issue before.
Many thanks,
Ross
Note - I am not a mechanic however I am happy to give easyish things a try.
** - I will be able to send photos at the weekend when I receive the car.
Post #652661 5th Jan 2023 6:01pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I am reasonably sure that the 2006 does an aux in port. Mine is at the back of the centre console, facing the rear passengers.
Post #652662 5th Jan 2023 6:03pm
toddo9
Hi Philip,
Thanks for replying. From research, 2006 seems to be a strange year due to transition from bmw to ford.
Some 2006 models have the aux in the back like you described, some don’t.
This one I am buying unfortunately doesn’t.
Maybe this opens a further question, is there any significance that it doesn’t have this AUX port in the back?
Ross
Post #652667 5th Jan 2023 6:22pm
Weegie
Re: Car play or aux lead - 2006
You don’t lose anything. It parallels the existing system and it’s a piece of cake to install.
If you don’t have AUX that would be a problem. John
GAP iiD BT
Post #652675 5th Jan 2023 6:48pm
garyRR
If you don't have AUX, it is possible, and there is an Android system out there, but it's quite a difficult job I understand.
If you wish to stream music without the hassle or just for the interim before investing a significant amount in the vehicle, it might be worth grabbing a Bluetooth to FM transmitter, then tune the stereo to the frequency on the adapter.
You can pick them up for around £10-15 on Amazon. 2015 Range Rover Autobiography 4.4 SDV8
Post #652680 5th Jan 2023 8:24pm
dhallworth
You should have an Aux port behind the centre console. All you’ll need to use it is a male 3.5mm cable. I bought a male to male 3.5mm cable and a cheap Bluetooth receiver from Amazon. When I switch that on it adds Bluetooth streaming to the car for less than 20 quid.
For me, as much as I’d love Apple CarPlay on mine, it wasn’t worth the costs being mentioned.
Post #652682 5th Jan 2023 8:37pm
GraemeC
Easy to add bluetooth streaming if you have a rear aux port - I wrote up a How To years ago Thumbs Up
https://www.fullfatrr.com/forum/topic24633.html 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #652755 6th Jan 2023 12:20pm
