![]() | Home > In Car Electronics (L322) > Car play or aux lead - 2006 |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
I am reasonably sure that the 2006 does an aux in port. Mine is at the back of the centre console, facing the rear passengers. |
toddo9 Member Since: 05 Jan 2023 Location: Wraysbury Posts: 2 ![]() ![]() ![]() |
Hi Philip,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
You don’t lose anything. It parallels the existing system and it’s a piece of cake to install. If you don’t have AUX that would be a problem. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
If you don't have AUX, it is possible, and there is an Android system out there, but it's quite a difficult job I understand.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
You should have an Aux port behind the centre console. All you’ll need to use it is a male 3.5mm cable. I bought a male to male 3.5mm cable and a cheap Bluetooth receiver from Amazon. When I switch that on it adds Bluetooth streaming to the car for less than 20 quid.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Easy to add bluetooth streaming if you have a rear aux port - I wrote up a How To years ago |
