Home > In Car Electronics (L322) > Smart key not found 2011 L322
klf400
Anyone had smart key not found?
I installed new key battery and it’s still the same, car will only start if I wave the key at knee level infront of the interior light
🤔 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #652364 2nd Jan 2023 8:13pm
AnotherMutley
I had this on my L322 and D4, being a bit of a cheap skate I bought a cheap battery still got the same message and issue, bought a Duracell and it worked straight away.
Post #652408 3rd Jan 2023 10:31am
the forum consensus is that a duracell bought from a reputable source is the 'battery' for key fobs..
i agree with the above comment . change your battery for another.. ... - .- -.
Post #652410 3rd Jan 2023 10:41am
Discotigger
+1 for what Stan says, I always use Duracell batteries for both the Keys and the FBH Remote.
Buying a cheap battery is false economy, especially when a Duracell battery is not much more expensive than any other make.
Only thing to check is the Battery 'Best before' date, some places will sell 'new' batteries which are actually 'out of date'.
Post #652445 3rd Jan 2023 3:08pm
klf400
Cheers guys I will certainly do just that , at the point of failure I installed a cheap Chinese battery out of a blister pack found in the cupboard as I had no other battery available.
I will post the outcome of a Duracell 👍 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #652473 4th Jan 2023 12:37am
garyRR
Just to say that Varta (Mercedes use Varta) are also just as good as Duracell. You can get a 4 pack on Amazon pretty affordably. 2015 Range Rover Autobiography 4.4 SDV8
Post #652483 4th Jan 2023 9:51am
klf400
Well guys guess what it didn’t work 😩 fitted a brand new Duracell battery with a date code in 2025 and still the same
Read all the codes and no fault found, apart from the usual ones, I wonder if there is a key loop type antenna somewhere?
Any idea’s 🤔 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #652578 4th Jan 2023 11:36pm
garyRR
Maybe worth checking the antenna plugs haven't come loose. The owner's manual tells you where they are. 2015 Range Rover Autobiography 4.4 SDV8
Post #652580 4th Jan 2023 11:54pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
I’ve had this a few times, fitted new battery, still says the same thing.
You need to put the fob on the instrument panel, above the steering wheel for a couple of minutes, and then start the car, seems ok after that.
Good luck
Post #652581 4th Jan 2023 11:54pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
remove any cheap phone chargers or any other electronic stuff you put last time.
Post #652582 4th Jan 2023 11:57pm
klf400
Well guys we have a result, disconnected the battery for about the 5 time over the past week and now it works , would of been nice to know what it was 🤔 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #653105 9th Jan 2023 8:11pm
