Home > In Car Electronics (L322) > Smart key not found 2011 L322 |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 |
I had this on my L322 and D4, being a bit of a cheap skate I bought a cheap battery still got the same message and issue, bought a Duracell and it worked straight away. |
3rd Jan 2023 9:31am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
the forum consensus is that a duracell bought from a reputable source is the 'battery' for key fobs..
3rd Jan 2023 9:41am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
+1 for what Stan says, I always use Duracell batteries for both the Keys and the FBH Remote.
3rd Jan 2023 2:08pm |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 |
Cheers guys I will certainly do just that , at the point of failure I installed a cheap Chinese battery out of a blister pack found in the cupboard as I had no other battery available.
3rd Jan 2023 11:37pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Just to say that Varta (Mercedes use Varta) are also just as good as Duracell. You can get a 4 pack on Amazon pretty affordably. 2015 Range Rover Autobiography 4.4 SDV8 |
4th Jan 2023 8:51am |
Well guys guess what it didn’t work 😩 fitted a brand new Duracell battery with a date code in 2025 and still the same
4th Jan 2023 10:36pm |
Maybe worth checking the antenna plugs haven't come loose. The owner's manual tells you where they are. 2015 Range Rover Autobiography 4.4 SDV8 |
4th Jan 2023 10:54pm |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
I’ve had this a few times, fitted new battery, still says the same thing.
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 162 |
remove any cheap phone chargers or any other electronic stuff you put last time. |
4th Jan 2023 10:57pm |
Well guys we have a result, disconnected the battery for about the 5 time over the past week and now it works , would of been nice to know what it was 🤔 1990 3.5 v8 defender
9th Jan 2023 7:11pm |
