Home > Technical (L322) > Clicking driving me nuts |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 399 |
Vid of it
1st Jan 2023 10:18pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Can't hear any sound on the video...?? Pete
2nd Jan 2023 12:44am |
Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 63 |
I can hear it very clearly (with headphones)
2nd Jan 2023 5:11am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
FBH? BMW i3 Electric Car
2nd Jan 2023 5:49am |
I haven't turned the car on yet or the fbh.
2nd Jan 2023 6:01am |
Defo there, I'd turn it up Its actually a sport Not anymore, 4.4 TDV8 now |
2nd Jan 2023 6:02am |
By climate control module you don't mean the blower fan that needs half the car removing to replace do you? Or do you mean the panel itself. Its actually a sport Not anymore, 4.4 TDV8 now |
2nd Jan 2023 6:03am |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 39 |
Nothing to bring to this discussion, but slightly amused when phrase "slightly inaccurate cabin temps" is used with L322. Coming from Saab´s, where you don´t ever need to touch the temp request unless you actually want to change what you are asking for, L322´s temp control is next to useless. Mine is basically cold or hot and there seems to be nothing wrong with the system, " it´s just that the Ford-system is not that good", answer you wouldn´t expect at this segment. |
2nd Jan 2023 7:47am |
Turned up fully, not muted and still no sound track at all from that short, which is weird as I can hear this one, from my early fatty no problem... https://www.youtube.com/shorts/vn0cwOZrIQg Is this the noise...?? If it is then it's the electrically controlled flap that takes air to the rear central vent, if you remove the side panel from the centre console you can find it behind there, I just unplugged it, it then sent air all the time to the rear but that's not really an issue... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
2nd Jan 2023 11:12am |
Nah that's not the noise. It's way quieter than your vid. It's defo on my vid but just really quiet. Its actually a sport
2nd Jan 2023 3:15pm |
It could be one of the other flaps, take off both sides of the transmission tunnel, one torx 20 up high at the back and they pull off...
2nd Jan 2023 4:01pm |
greenrover Member Since: 02 Jan 2023 Location: Idaho Posts: 12 |
Just the panel itself. It's a tiny fan. https://www.youtube.com/watch?v=RQTcT_vmc68 2006 HSE 4.4 gasser |
3rd Jan 2023 5:34am |
I defo think it's an actuator.
10th Jan 2023 9:40pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
Having had the same on 2 different cars my money is on the blend motor/actuator behind the panel by your left knee. One screw to remove the panel and the motor just snaps in or out. 5 min job. One i took apart, cleaned, and lubed and it cured the issue. The 2nd did not respond to cleaning so I swapped it for a used one.
11th Jan 2023 12:02am |
