Home > Technical (L405) > Full size spare wheel TPMS
SVAuto_Man
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Hi all,
I have the warning that the spare wheel is low on pressure. It’s full size with the sensor etc.
I checked the pressure and it’s about 37PSI. I topped it up to 40PSI but still getting the error after 3 days or so. Any ideas?? 2019 L405 SV Autobiography
Post #651944 29th Dec 2022 3:45pm
Kot
I get that at start up once started it's started, it disappears.
Maybe its time to charge the battery the gremlins are coming out Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #651945 29th Dec 2022 3:49pm
SVAuto_Man
Yeah that’s what mine does. On for about a minute. Car is a 2020 so main batt should be fine. Did over 600 miles driving and still does it 2019 L405 SV Autobiography
Post #651946 29th Dec 2022 3:50pm
Phoenix
The spare should be inflated to 'high load' pressure, it's checked every 13 hours so it can take a while for everything to settle down.
Post #651961 29th Dec 2022 5:44pm
SVAuto_Man
Any idea what’s the higher load pressure? I guesss that’s 13 hours in total, not 13 hours complete driving? 2019 L405 SV Autobiography
Post #651963 29th Dec 2022 6:01pm
my spare is at 40psi and the tpms reads it with no low pressure warnings.
i suggest taking the spare out for a few journeys and then replace it back..this could reboot the system.. ... - .- -.
Post #651964 29th Dec 2022 6:05pm
SVAuto_Man
Will try that but not easy getting it in and out lol 2019 L405 SV Autobiography
Post #651966 29th Dec 2022 6:19pm
44 or 46psi depending on wheel size.
46 is what mine is at, based on the logic that I can carry a pressure gauge & can therefore reduce to the required pressure.
Post #651968 29th Dec 2022 6:32pm
Phoenix
IIRC it's 13 hours in total, the pressure needs to be high enough to be over the 'reinflated' threshold so above 42psi should clear the warning - but it may take up to 13 hours for the warning to disappear, depending upon how long ago the last check was made, if you have access to a TPMS diag. tool, you can trigger the sensors to force an update. That's how we used to do it if the spare had a puncture repair or replacement tyre fitted.
Post #651970 29th Dec 2022 6:47pm
SVAuto_Man
Fab. Will put it above 42psi. Think it’s the cold snap we had set it off. Will try without the spare for a day, then put it back, see if that will trip it etc 2019 L405 SV Autobiography
Post #651972 29th Dec 2022 6:51pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I have the same issue, but only since we had that cold snap. Another chore for the weekend; getting a forecourt airline up and into the wheel well is a right PITA though! Might treat myself to one of those inflators from Halfrauds as the Mini needs regular top ups on its run flats, so would be useful to have anyway.
Post #652052 30th Dec 2022 1:39pm
SVAuto_Man
I have the Roybi one and it’s fab 2019 L405 SV Autobiography
Post #652056 30th Dec 2022 2:00pm
If you have any 18v power tools, then the corresponding inflator is worth a look.
I can thoroughly recommend the DeWalt one - as I already had the charger and batteries
Post #652081 30th Dec 2022 4:20pm
cxdood
United States 2016 Range Rover HSE 3.0 SC V6 Santorini Black
I have the same DeWalt one and like it. One of the selling points for me was that you set the pressure and then it shuts off once the desired pressure is reached. I wish it could also deflate to a set pressure.
I don't have DeWalt batteries, but bought an adapter for Makita/DeWalt on the internet since I have Makita batteries. This adapter is not officially recommended but it works. Before getting that adapter I used the 12V wire to connect to the cigarette 12V outlet in the car and this was cumbersome and also required having the car running. L405 2016 - Supercharged V6 petrol 380hp
Post #652401 3rd Jan 2023 6:37am
