![]() | Home > Technical (L405) > Full size spare wheel TPMS |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1265 ![]() ![]() |
I get that at start up once started it's started, it disappears.
SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110 ![]() ![]() ![]() |
Yeah that’s what mine does. On for about a minute. Car is a 2020 so main batt should be fine. Did over 600 miles driving and still does it 2019 L405 SV Autobiography |
The spare should be inflated to 'high load' pressure, it's checked every 13 hours so it can take a while for everything to settle down. |
Any idea what’s the higher load pressure? I guesss that’s 13 hours in total, not 13 hours complete driving? 2019 L405 SV Autobiography |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
my spare is at 40psi and the tpms reads it with no low pressure warnings.
Will try that but not easy getting it in and out lol 2019 L405 SV Autobiography |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
44 or 46psi depending on wheel size.
46 is what mine is at, based on the logic that I can carry a pressure gauge & can therefore reduce to the required pressure. |
IIRC it's 13 hours in total, the pressure needs to be high enough to be over the 'reinflated' threshold so above 42psi should clear the warning - but it may take up to 13 hours for the warning to disappear, depending upon how long ago the last check was made, if you have access to a TPMS diag. tool, you can trigger the sensors to force an update. That's how we used to do it if the spare had a puncture repair or replacement tyre fitted. |
Fab. Will put it above 42psi. Think it’s the cold snap we had set it off. Will try without the spare for a day, then put it back, see if that will trip it etc 2019 L405 SV Autobiography |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
I have the same issue, but only since we had that cold snap. Another chore for the weekend; getting a forecourt airline up and into the wheel well is a right PITA though! Might treat myself to one of those inflators from Halfrauds as the Mini needs regular top ups on its run flats, so would be useful to have anyway. |
I have the Roybi one and it’s fab 2019 L405 SV Autobiography |
If you have any 18v power tools, then the corresponding inflator is worth a look.
cxdood Member Since: 05 Jul 2020 Location: USA Posts: 58 ![]() ![]() ![]() |
I have the same DeWalt one and like it. One of the selling points for me was that you set the pressure and then it shuts off once the desired pressure is reached. I wish it could also deflate to a set pressure.
