Home > Maintenance & Mods (L322) > Brakes
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
Brakes
Right lets see how this pans out - caliper guide/slide pins which option?
1, Clean and re-grease and if so what grease?
2, Clean and leave un-greased?
Does grease attract dirt and therefore cause it to bind, thoughts.
Over to you.......
Post #651459 22nd Dec 2022 4:49pm
JayGee
If the callipers are alloy I'd grease them but also I'd also use a new set of pins which will be plated and reduce galvanic corrosion. If you don't have brake specific grease I'd not grease them as you don't want grease migrating onto the disks or pads. 2012 TDV8 Vogue (L322)
Post #651461 22nd Dec 2022 5:08pm
Rambles
On the 2011 4.4, caliper sliders are only on the rear. Red rubber grease.
Post #651481 22nd Dec 2022 7:42pm
JayGee
Sorry yes if it’s a floating calliper on sliding pins it needs grease. My answer refers to retaining pins on fixed calipers. 2012 TDV8 Vogue (L322)
Post #651482 22nd Dec 2022 8:00pm
Phoenix
Don't agree - for a start, there's no rubber involved other than the gaiter, secondly, the OEM grease is a silicone one, with much lower viscosity than red rubber grease so will allow the pins to slide more easily - therefore the pads will withdraw by the design distance reducing brake wear and heat.
Don't use copperslip or similar under any circumstances.
Post #651487 22nd Dec 2022 8:37pm
TDV8 Paul
Out of interest- why not copperslip? 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #651649 26th Dec 2022 8:14am
Phoenix
Because the lubricant that is the 'carrier' for the copper won't withstand even moderate braking temperatures and separates from the copper, leaving a thick metal paste, which causes the slides to bind.
Most brake slide pins are lubricated with silicone based lubricant that has a high melting point.
The days of slathering every braking component in copperslip firmly belong in the last century - the technology used is very different now, most brake pads or pad slides have specific coatings or overlays to avoid the need for any lubricants, which tend to collect brake dust and turn into a binding paste anyway.
Post #651650 26th Dec 2022 9:39am
TDV8 Paul
Interesting, thanks for that, I never really thought of it like that 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #651731 27th Dec 2022 4:18pm
Mikey
Copper grease also reacts with rubber, damaging the pin/piston boots, which then allows moisture in, and causes the very problem you were trying to prevent Laughing
Ceramic grease for the pad contact surfaces, and silicone/rubber for the slide pins. We don't use copper grease in the workshop at all anymore Thumbs Up
Post #651772 28th Dec 2022 5:11am
Discofish
Thanks all, some interesting points here.
looks like I'm outside at some point in the very near future firstly giving everything a good clean then applying various slippery substances Laughing
as per normal on this forum ask and you shall receive words of wisdom Thumbs Up
Post #652083 30th Dec 2022 4:46pm
Weegie
Any thoughts on teflon grease for slide pins? John
GAP iiD BT
Post #652095 30th Dec 2022 6:28pm
Phoenix
Well, I must admit, I thought that would be an easy one to answer....
A quick look suggests there are many different types, high viscosity, high temperature, 'marine' etc. etc.
The first one that came up on Amazon has this in the description
Quote:
Prevents wear and distortion of bearings even when steering and bearings are brutally beaten;
A unique thickener of the finish line prevents separation of oils and repels water even when the fat is immersed;
The exceptional strength of the synthetic oil film does not give in under high pressure;
https://www.amazon.co.uk/Finish-Line-Teflo...YYYA?psc=1
First line - there is little movement or pressure, so maybe over spec.?
second line - thickener adds viscosity - great for bearing races etc. not so great for something that needs lubrication but also low drag
third line - oil based, more of a loaded oil than a true grease.
I'd still say silicone grease is the better option. C. Bennis sell the right stuff in small tins https://www.ebay.co.uk/itm/172158923504?epid=1949186201
Post #652096 30th Dec 2022 6:42pm
Weegie
I have some that I used on the boat to grease the tracks for the sail hoist. Thought that would be a similar use to slide pins though not a high temperature situation.
The link you supplied does specify high temperature.👍
I think it is a good option and doesn’t have a problem with incompatibility with seals etc
The other thing I have is aluminium based grease I used for Ham radio aerial connections but not sure about it as it metal based though aluminium as opposed to copper. John
GAP iiD BT
Post #652099 30th Dec 2022 7:05pm
Phoenix
I'd think a sail hoist takes a much higher load than the slide pins so viscosity is not a consideration - it'll probably be OK but personally I'd spend the £3.85... I realise you're Jockanese and I'm from North Yorkshire so we have similar spending concerns... Wink
Post #652101 30th Dec 2022 7:08pm
Weegie
Aye yer reet there. Huv tae dig intae ma sporran. Very Happy
Did you see the addition to my last post? John
GAP iiD BT
Post #652104 30th Dec 2022 7:17pm
