Home > Maintenance & Mods (L322) > Brakes |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3227 |
If the callipers are alloy I'd grease them but also I'd also use a new set of pins which will be plated and reduce galvanic corrosion. If you don't have brake specific grease I'd not grease them as you don't want grease migrating onto the disks or pads. 2012 TDV8 Vogue (L322) |
22nd Dec 2022 5:08pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 801 |
On the 2011 4.4, caliper sliders are only on the rear. Red rubber grease. |
22nd Dec 2022 7:42pm |
Sorry yes if it’s a floating calliper on sliding pins it needs grease. My answer refers to retaining pins on fixed calipers. 2012 TDV8 Vogue (L322) |
22nd Dec 2022 8:00pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Don't agree - for a start, there's no rubber involved other than the gaiter, secondly, the OEM grease is a silicone one, with much lower viscosity than red rubber grease so will allow the pins to slide more easily - therefore the pads will withdraw by the design distance reducing brake wear and heat. Don't use copperslip or similar under any circumstances. |
22nd Dec 2022 8:37pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
Out of interest- why not copperslip? 2009 (2010 MY) 5.0 Supercharged Autobiography
26th Dec 2022 8:14am |
Because the lubricant that is the 'carrier' for the copper won't withstand even moderate braking temperatures and separates from the copper, leaving a thick metal paste, which causes the slides to bind.
26th Dec 2022 9:39am |
Interesting, thanks for that, I never really thought of it like that 2009 (2010 MY) 5.0 Supercharged Autobiography
27th Dec 2022 4:18pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1755 |
Copper grease also reacts with rubber, damaging the pin/piston boots, which then allows moisture in, and causes the very problem you were trying to prevent Ceramic grease for the pad contact surfaces, and silicone/rubber for the slide pins. We don't use copper grease in the workshop at all anymore |
28th Dec 2022 5:11am |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 104 |
Thanks all, some interesting points here.
30th Dec 2022 4:46pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3234 |
Any thoughts on teflon grease for slide pins? John
30th Dec 2022 6:28pm |
Well, I must admit, I thought that would be an easy one to answer....
https://www.amazon.co.uk/Finish-Line-Teflo...YYYA?psc=1 First line - there is little movement or pressure, so maybe over spec.? second line - thickener adds viscosity - great for bearing races etc. not so great for something that needs lubrication but also low drag third line - oil based, more of a loaded oil than a true grease. I'd still say silicone grease is the better option. C. Bennis sell the right stuff in small tins https://www.ebay.co.uk/itm/172158923504?epid=1949186201 |
30th Dec 2022 6:42pm |
I have some that I used on the boat to grease the tracks for the sail hoist. Thought that would be a similar use to slide pins though not a high temperature situation.
30th Dec 2022 7:05pm |
I'd think a sail hoist takes a much higher load than the slide pins so viscosity is not a consideration - it'll probably be OK but personally I'd spend the £3.85... I realise you're Jockanese and I'm from North Yorkshire so we have similar spending concerns... |
30th Dec 2022 7:08pm |
Aye yer reet there. Huv tae dig intae ma sporran.
30th Dec 2022 7:17pm |
