Home > My Range Rover > Finally, A Full Fat.
Page 3 of 5 <12345>
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Ahh, to copper grease wheel nuts or not, I suspect that’ll divide opinion!
Personally I do apply a light coating to aid future removal with no apparent adverse effects.
I also spray ACF50 under the stainless cap to try & keep the moisture out to avoid them corroding / swelling.
Post #653383 12th Jan 2023 5:52pm
Kot
The threads should be dry at 140nm if you put on grease etc you will over torque them
Apply a small amount of grease to the hub spigot and associated wheel spigot bore before installation. Make
sure the grease does not come into contact with the vehicles braking components, or wheel studs threads.
Failure to follow these may result in personal injury.
 2018 SE SDV8 4.4 Byron Blue
Post #653384 12th Jan 2023 6:06pm
mgrover
Ooo might try the ACF50, hopefully keeps these nice and "new"
hmm tbf torquing to 140nm and probably plenty of room to overtorque given how tight they were before.
I mean I literally had to deadlift the breaker bar with both hands for some of them.
i sprayed with WD40 for now. tbf just leaving at 140nm will probably be enough. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #653388 12th Jan 2023 6:34pm
JayGee
+1 Thumbs Up
There is a lot of force going through these studs with these big wheels (some other 4x4's have 6 studs). If you grease them they will not be secure and the torque needed to secure them with grease with stretch the studs. If you are worried about them seizing just go round them every so often loosening and retorquing them. Infact you should be doing this anyway on any car. 2012 TDV8 Vogue (L322)
Post #653393 12th Jan 2023 6:55pm
mgrover
tbf ive never had this problem with any other car.
so maybe it was just someone having a good time with an air gun and not torquing to spec. Its actually a sport Sad
Post #653394 12th Jan 2023 6:58pm
JayGee
Were they tight due to over tightening or due to corrosion? 2012 TDV8 Vogue (L322)
Post #653395 12th Jan 2023 7:03pm
mgrover
I'd say both.
There was defo rust and it was clearly way past 140nm Its actually a sport Sad
Post #653397 12th Jan 2023 7:13pm
Phoenix
Breakaway torque is higher than tightening torque, there is a calculation based upon many factors, I'd guess it's north of 180Nm for Landrover wheel nuts.
Sometimes the corrosion between the split washers can be the source of higher than normal breakaway, sometimes its alloy corrosion on the wheels binding on the nuts.
Lubricating threads that are specified to be dry can lead to excessively over-torquing as it removes the friction, so you can go past the elastic point of the stud into plasticity (where the thread is permanently stretched, and the structure of the metal changed). Repeatedly torquing without releasing previous torque can also lead to over-torquing, temperature changes can also have an effect.
Post #653403 12th Jan 2023 8:28pm
Gremlin500
@Pheonix:
Very well explained Bow down
No kind of lube has any place on the studs, -period. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #653404 12th Jan 2023 8:48pm
Phoenix
Thanks, some manufacturers (Audi for one) do specify a lubricant for the wheel studs (or bolts, I forget which they have), it's not any old grease or oil though, and the torque is a bit lower than other VWG vehicles that use the same parts for the hubs & nuts/bolts.
Years ago, I came across a dry corrosion inhibitor that was claimed to not alter the friction properties of threads, it had a NSN so was clearly used by the military somewhere in NATO - and had presumably been assessed to work as advertised. It was a grey colour, I don't think it was graphite based though.
Post #653405 12th Jan 2023 9:08pm
mgrover
Well I guess when I've got wheels off I'll give em a good clean and torque em right and probably acf50 the wheel nuts to avoid swelling.
But tbf they are brand new wheel nuts so if they last another 170k be fine Its actually a sport Sad
Post #653409 12th Jan 2023 9:54pm
Gremlin500
If your worried about corrosion on the threads, it might be OK to use a low-strength Loctite type product as a barrier, however this would need to be researched carefully: in its liquid state I suppose its still acting as a lubricant, however poor.
Best answer is to periodically loosen & re-torque as suggested above, and leave dry. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #653422 13th Jan 2023 10:15am
mgrover
Tbf this car was next to the seaside before. Now its in the heartland of Leeds. So unsure if rust will be hte same type of problem here? Its actually a sport Sad
Post #653425 13th Jan 2023 10:26am
will that panel you're selling not fit in your FF...obviously a bit of fettling will be required.. ... - .- -.
Post #653429 13th Jan 2023 11:01am
mgrover
Am guessing it will as a double din. But it won't look as nice as the icebox version. It worked in the RRS because am guessing it was central
while for the L322 it'll be right at the top of the dash so would ruin the lines.
I know, I know, first world problems Laughing Its actually a sport Sad
Post #653432 13th Jan 2023 11:38am
Page 3 of 5 <12345>
