Home > Technical (L405) > FBH Question
cass
FBH Question
Hi
The FBH on my L405 works fine but when I press the remote the green light flashes quickly for about 15 seconds and the unit doesn't start up, I press it a second time and the green light flashes slowly and the unit starts up.
Is this normal or is this some secret code warning of imminent disaster looming?
Cheers
Post #650789 14th Dec 2022 7:35pm
mjdronfield
My L322 does that sometimes. I think it might be as the car is “asleep” on the first press and maybe systems need to come on a bit. Second press is always good….
I wouldn’t say it’s anything to worry about, but happy to be corrected….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #650804 14th Dec 2022 10:21pm
cass
Thanks for that. It sounds very logical, I don't recall my l322 doing this but the FBH isn't reliable on mine. I'm just pleased that it does fire up eventually on the L405.
Post #650823 15th Dec 2022 12:21pm
ilard
I think it might be a low battery in your FBH remote fob. Perhaps worth changing this to see if that behaviour stops. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #650944 16th Dec 2022 9:34pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
I think it is normal. if it doesn't connect when you first push the button. It is also to give you feedback that the car received the command.
This video also talks about the remote for the FBH
https://youtu.be/kNzsnhCNc1g SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #650956 17th Dec 2022 6:27am
cass
Thanks for the replies - I did consider the low battery option but as the FBH still works every time, I can live with having to press the button twice.
Other than changing oils and filters I believe that it should be illegal to do anything to a Range Rover if it's working.
Post #650985 17th Dec 2022 4:11pm
Perce
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
Re: FBH Question
cass wrote:
Hi
Cheers
Mine flashes quickly on the first press, the fbh then starts up about a minute later ( roughly, I haven’t timed it) and works fine. Perhaps give it more of a chance before pressing again, and see if yours does the same
Post #651100 19th Dec 2022 10:08am
cass
10 out of 10 - mine did exactly that, I was just being impatient
Post #651248 20th Dec 2022 12:14pm
