Home > Technical (L405) > FBH Question |
My L322 does that sometimes. I think it might be as the car is “asleep” on the first press and maybe systems need to come on a bit. Second press is always good….
14th Dec 2022 10:21pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 732 |
Thanks for that. It sounds very logical, I don't recall my l322 doing this but the FBH isn't reliable on mine. I'm just pleased that it does fire up eventually on the L405. |
15th Dec 2022 12:21pm |
ilard Member Since: 21 Oct 2012 Location: London Posts: 708 |
I think it might be a low battery in your FBH remote fob. Perhaps worth changing this to see if that behaviour stops. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
16th Dec 2022 9:34pm |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 461 |
I think it is normal. if it doesn't connect when you first push the button. It is also to give you feedback that the car received the command.
17th Dec 2022 6:27am |
Thanks for the replies - I did consider the low battery option but as the FBH still works every time, I can live with having to press the button twice.
17th Dec 2022 4:11pm |
Perce Member Since: 30 Jan 2012 Location: Milton Keynes Posts: 163 |
Mine flashes quickly on the first press, the fbh then starts up about a minute later ( roughly, I haven’t timed it) and works fine. Perhaps give it more of a chance before pressing again, and see if yours does the same |
19th Dec 2022 10:08am |
10 out of 10 - mine did exactly that, I was just being impatient |
20th Dec 2022 12:14pm |
