Home > Maintenance & Mods (L405) > FFRR L405 Self Deploying Side Steps |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
FFRR Self Deploying SIDE STEPS Report post
4th Dec 2022 6:48pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1165 |
The only stuff I have seen is what they use in Australia on the tubs of the utes which is sprayed on and called ` Rhino`protection |
4th Dec 2022 7:23pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16227 |
JLR changed the steps to plastic instead of painted aluminium in later models just incase you didn’t know? 👍 |
4th Dec 2022 10:38pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1296 |
@CTC:
4th Dec 2022 11:47pm |
What I meant was, if members keep an eye out on selling platforms? Maybe they will find later type steps on offer? That way they can simply swap them over and have the newer type of step that will never degrade again… |
5th Dec 2022 12:44pm |
Hi Craig,
5th Dec 2022 2:40pm |
Take the Allen head bolts out and tap the underside in an upwards motion with a rubber mallet… Always come off for me sir… Use a bigger hammer? |
5th Dec 2022 5:50pm |
@Cam-Tech-Craig:
5th Dec 2022 7:46pm |
They simply drop in from the top sir… Maybe that’s your mistake? Bashing them outwards won’t work… Try removing the bolts then tapping them upwards sir |
5th Dec 2022 9:03pm |
Thank you Craig, helpful as always! 👍🏼 “If it ain’t broke, don’t fix it” -where’s the fun in that? |
5th Dec 2022 9:08pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3024 |
If you can't get access to hit them from underneath, putting the car on high and then using a little block of wood and a jack might work. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
5th Dec 2022 11:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35086 |
or, put FF in offroad mode, stick a piece of wood under the step and then lower FF...
6th Dec 2022 9:23am |
Trust me Stan, the OP just needs to give them a knock with a mallet (in the correct orientation!) to remove them… Applying near 3 tonne of force to cast aluminium brackets sounds a bit scetchy to me sir 😬😳🥴 |
6th Dec 2022 11:28am |
i know Craig ,mine come off with a little knock upwards..
6th Dec 2022 12:15pm |
