Home > Maintenance & Mods (L405) > FFRR L405 Self Deploying Side Steps
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
FFRR Self Deploying SIDE STEPS Report post
Guys
2 of our FFRR's the side steps are looking a bit sorry - The cars are L405's
Has anyone ever tried that BLACK STUFF thats got pieces on plastic metal in the paint - its the stuff you see on URBAN Truck Compnay London
The top of the side steps is wearing a bit thin in places
Rather than just taking them off and getting them stove enamelling in Black
There must be a more long term solution thats heard wearing
whats do you recommend
Thank you in advance
Post #649845 4th Dec 2022 5:48pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
The only stuff I have seen is what they use in Australia on the tubs of the utes which is sprayed on and called ` Rhino`protection
Post #649849 4th Dec 2022 6:23pm
Gremlin500
Lookup "TANK" 2-pack epoxy Bedliner paint on eBay, not full of bits of anything, smooth satin finish just like the original, but much tougher then Hammerite, or probably what was on there before. Prep is king, so bead blast down to bare smooth metal, acid etch spray primer 2-3 coats rubbing down lightly between coats, then a couple of light coats of primer before applying 2 coats of the Berliner coat, give it a week to cure hard before installing. It's a Summer job unless you have a heated paint shop.
As a quick bodge to get you to the warmer weather, smooth black hammerite brushed on after masking the shiny bits will keep the worst at bay & buy some time. If it's too cold you wil get brush marks! Sad “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649854 4th Dec 2022 7:01pm
JLR changed the steps to plastic instead of painted aluminium in later models just incase you didn’t know? 👍
Post #649871 4th Dec 2022 9:38pm
Gremlin500
@CTC:
Makes sense.
“Just take them off” Rolling with laughter ☹️ “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649877 4th Dec 2022 10:47pm
What I meant was, if members keep an eye out on selling platforms? Maybe they will find later type steps on offer? That way they can simply swap them over and have the newer type of step that will never degrade again… Thumbs Up
Post #649897 5th Dec 2022 11:44am
Gremlin500
Hi Craig,
Swapping for the later ones is fine, but only if you can remove the originals.
I simply could not get mine to budge after taking all four bolts out, any tips on doing that? Bow down
I think refinishing with an epoxy type paint will work OK, but given the abrasion over time, solid plastic makes sense. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649903 5th Dec 2022 1:40pm
Take the Allen head bolts out and tap the underside in an upwards motion with a rubber mallet… Always come off for me sir… Use a bigger hammer? Whistle Thumbs Up
Post #649917 5th Dec 2022 4:50pm
Gremlin500
@Cam-Tech-Craig:
Thanks Craig, I was bashing outwards with a very large rubber mallet, maybe try a change of direction next time, no amount of PLUS-GAS made any difference. Bashing upwards is MUCH easier when you have a vehicle lift! Sad
It would be useful to see how they fit onto the brackets, I'll have another go in the Spring Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649928 5th Dec 2022 6:46pm
They simply drop in from the top sir… Maybe that’s your mistake? Bashing them outwards won’t work… Try removing the bolts then tapping them upwards sir Thumbs Up
Post #649939 5th Dec 2022 8:03pm
Gremlin500
Thank you Craig, helpful as always! 👍🏼 “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649941 5th Dec 2022 8:08pm
dhallworth
If you can't get access to hit them from underneath, putting the car on high and then using a little block of wood and a jack might work. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #649953 5th Dec 2022 10:16pm
or, put FF in offroad mode, stick a piece of wood under the step and then lower FF...
(undo the securing bolts/screws first. Thumbs Up) ... - .- -.
Post #649961 6th Dec 2022 8:23am
Trust me Stan, the OP just needs to give them a knock with a mallet (in the correct orientation!) to remove them… Applying near 3 tonne of force to cast aluminium brackets sounds a bit scetchy to me sir 😬😳🥴
Post #649971 6th Dec 2022 10:28am
i know Craig ,mine come off with a little knock upwards.. Thumbs Up
i was being facetious ... Wink ... - .- -.
Post #649974 6th Dec 2022 11:15am
