Home > Technical (L405) > LR036573 brake caliper actuator
cupples8267
Scotland 2016 Range Rover Vogue SE SDV8 Santorini Black
Does anyone know who manufactures the original brake caliper actuators, part number LR036573? I think it may be TRW, but not sure.
Post #649491 29th Nov 2022 9:40pm
Gremlin500
TRW definitely make these, they have TRW embossed into the plastic. One thing to be aware of is there are 2 different types of electrical connector, one with rounded plug, and one with rectangular plugs which has rounded-off corners (see pic) Thumbs Up
 “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649496 29th Nov 2022 10:02pm
cupples8267
Thank you!
Post #649497 29th Nov 2022 10:08pm
cupples8267
Will the faults need clearing once I replace the actuator or can I just cycle through a handbrake service mode?
Post #649775 3rd Dec 2022 7:42pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Silly question, are they easy to install? been told the casing on mine are split and need replacing
Post #649776 3rd Dec 2022 7:56pm
Phoenix
Put the EPB in service position, remove two bolts and the electrical connector, fit new part, take EPB out of service - might need to cycle the EPB a couple of times afterwards, personally, I'd put it in 'service' then disconnect the battery if you don't have the ability to clear DTC's.
Post #649777 3rd Dec 2022 8:10pm
cupples8267
Thank you.
Post #649778 3rd Dec 2022 8:13pm
DrF
Been quoted £700 for both to be replaced, seems a bot high but that is MD
Post #649779 3rd Dec 2022 8:17pm
cupples8267
There are genuine TRW ones on EBay for £90. (TRW is the original manufacturer if you look on the back of the ones on your car)
Post #649780 3rd Dec 2022 8:20pm
Phoenix
Genuine parts are roughly £250 a side so ~1.2 hours fitting is about right.
Post #649782 3rd Dec 2022 8:38pm
DrF
Perfect, thank you Thumbs Up Thumbs Up
Post #649783 3rd Dec 2022 9:06pm
Gremlin500
Wow! Shocked
I’m glad I have 2 spares!
No way 1.2 hours to fit though, about 30 minutes max DIY, I’ve done it myself, unfortunately twice. Censored “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #649787 3rd Dec 2022 10:39pm
TJH1985
Ours were done by a MD, but I did a friends on the drive it’s a 10minute job if you just replace them but maybe a 30 minute job if you take your time and clean up the calliper and any corrosion caused by the water ingress.
Worth doing sooner than later, as it certainly causes calliper corrosion. Thumbs Up
You don’t even need to jack the car up etc Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #649788 3rd Dec 2022 10:49pm
DrF
Thanks for the advice, I will get booked in asap
Post #649789 3rd Dec 2022 11:07pm
They quite often rot on but are quite straightforward to replace Thumbs Up
Post #649790 3rd Dec 2022 11:54pm
