![]() | Home > Technical (L405) > LR036573 brake caliper actuator |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1688 ![]() ![]() ![]() |
TRW definitely make these, they have TRW embossed into the plastic. One thing to be aware of is there are 2 different types of electrical connector, one with rounded plug, and one with rectangular plugs which has rounded-off corners (see pic) |
cupples8267 Member Since: 20 Aug 2020 Location: Stg Posts: 67 ![]() ![]() ![]() |
Thank you! |
Will the faults need clearing once I replace the actuator or can I just cycle through a handbrake service mode? |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1467 ![]() ![]() ![]() |
Silly question, are they easy to install? been told the casing on mine are split and need replacing |
Put the EPB in service position, remove two bolts and the electrical connector, fit new part, take EPB out of service - might need to cycle the EPB a couple of times afterwards, personally, I'd put it in 'service' then disconnect the battery if you don't have the ability to clear DTC's. |
Thank you. |
Been quoted £700 for both to be replaced, seems a bot high but that is MD |
There are genuine TRW ones on EBay for £90. (TRW is the original manufacturer if you look on the back of the ones on your car) |
Genuine parts are roughly £250 a side so ~1.2 hours fitting is about right. |
Perfect, thank you |
Wow! |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Ours were done by a MD, but I did a friends on the drive it’s a 10minute job if you just replace them but maybe a 30 minute job if you take your time and clean up the calliper and any corrosion caused by the water ingress.
Thanks for the advice, I will get booked in asap |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
They quite often rot on but are quite straightforward to replace |
