![]() | Home > General > Panic beginning to set in |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3869 ![]() ![]() ![]() |
I had a great 5.0L 322 in great condition - sold it to another member on here at a bargain price. Bought an L405 and paid top dollar for the spec I wanted but reading about the aluminium corrosion and other issues I wonder If I have made a mistake. Time will tell I suppose it is a much better vehicle for me (more luxury car than mud plugger) I don't think I've ever been off road and probably never will neither will I ever tow anything. The performance of the L322 was just bonkers but fun while I had it. Geoff |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
That would be the main reason for me to change - not having to worry about rust/corrosion.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
£10k Geoff and I’ll take the worry off your shoulders |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Steel can be cut out and good metal welded back into place While a similar method with aluminium, its nowhere near as easy or simple to repair... |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Where is that corroded mount Mikey? It would be very useful to be able to check it before the corrosion warranty expires at 6 years old 👍 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
Red Merle - It’s where the rear subframe mounts to the body of the vehicle I believe from Mikey’s previous post.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
While a similar method with aluminium, its nowhere near as easy or simple to repair...[/quote]
It is indeed at the rear of the car, infront of the rear subframe, but hidden under the brace infront
That was what I couldn’t figure out either.
How old was the car at the time Mikey? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I can imagine a few DIY bodges stuffing the cavity around the mount bosses with reinforced glass fibre matting of some type and hiding the repair under bitumen under seal , but I can’t picture a quality type repair. ??
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
Tempted Geoff?
7 or 8 years old... |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3758 ![]() ![]() |
She hasn’t been in the sea at anytime has she ? Boat launching or a splash through salt water ? I have seen corrosion like this before on a friends RR Sport used for launching a jet ski 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
