Home > General > Panic beginning to set in
supershuttle
I had a great 5.0L 322 in great condition - sold it to another member on here at a bargain price. Bought an L405 and paid top dollar for the spec I wanted but reading about the aluminium corrosion and other issues I wonder If I have made a mistake. Time will tell I suppose it is a much better vehicle for me (more luxury car than mud plugger) I don't think I've ever been off road and probably never will neither will I ever tow anything. The performance of the L322 was just bonkers but fun while I had it. Geoff
Post #624513 23rd Feb 2022 1:03pm
mjdronfield
That would be the main reason for me to change - not having to worry about rust/corrosion.
Still love my L322, longest I’ve kept a car. In my 7th year now….
I’d love a panaramic roof and the top Meridian hifi, but it won’t be a cheap change….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #624519 23rd Feb 2022 2:02pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
From my experience working on both models there’s no where near the corrosion problems on the l405 that the 322 had, that said they do suffer with bolt on corrosion, I.E brake pipes and ARC pipes with the tank saddle thrown in for good measure, but the main body seems better IMHO.
I’ve waxoyledl mine so hope it’s done the trick for longer life of parts mentioned above.
Post #624554 23rd Feb 2022 5:56pm
£10k Geoff and I’ll take the worry off your shoulders Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #624556 23rd Feb 2022 6:03pm
Mikey
Steel can be cut out and good metal welded back into place
While a similar method with aluminium, its nowhere near as easy or simple to repair...
Post #624570 23rd Feb 2022 7:25pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Where is that corroded mount Mikey? It would be very useful to be able to check it before the corrosion warranty expires at 6 years old 👍
Post #624574 23rd Feb 2022 7:50pm
dhallworth
Red Merle - It’s where the rear subframe mounts to the body of the vehicle I believe from Mikey’s previous post.
Steel subframe, steel bolt and an aluminium body causing galvanic corrosion. I’d guess it’s not visible without dropping the subframe though.
Mikey - Can that be repaired? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #624579 23rd Feb 2022 8:15pm
diesel Dave
While a similar method with aluminium, its nowhere near as easy or simple to repair...[/quote]
Not saying they don’t as you have the evidence in the pic, but I work on these on a daily basis and have not seen one like you point out, (yet). But I will be taking a closer look at mine and a few others and report back if I find any.
By the way have you repaired that one and have pics of the repair?
Post #624582 23rd Feb 2022 8:18pm
Mikey
It is indeed at the rear of the car, infront of the rear subframe, but hidden under the brace infront
Both sides were holed, and corrosion had also set in around all the main subframe mounts
We did not repair, we informed the customer who told us repair the original fault (leaky ARC pipes) and put it back together so he could trade the car in...
Being aluminium, I don't know how to even begin repairing that. And the floor pan is bonded together, not welded. Steel is easy to repair, alu, not so much Neutral
Post #624600 23rd Feb 2022 10:12pm
dhallworth
That was what I couldn’t figure out either.
It’s shaped and has the structural support in it.
Shame there’s no easy way to check it really I guess. I’ve been looking at the earlier L405’s recently but think I’ll stick to my problem child for a bit longer having seen some of the recent horror stories! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #624603 23rd Feb 2022 10:44pm
Red Merle
How old was the car at the time Mikey?
Post #624635 24th Feb 2022 1:51pm
Baltic Blue
I can imagine a few DIY bodges stuffing the cavity around the mount bosses with reinforced glass fibre matting of some type and hiding the repair under bitumen under seal , but I can’t picture a quality type repair. ??
Post #624637 24th Feb 2022 2:21pm
markdotreed
Tempted Geoff?
https://www.autotrader.co.uk/car-details/2...amp;page=1 Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #625010 28th Feb 2022 4:36pm
Mikey
7 or 8 years old...
Post #625019 28th Feb 2022 5:00pm
Vogue
She hasn’t been in the sea at anytime has she ? Boat launching or a splash through salt water ? I have seen corrosion like this before on a friends RR Sport used for launching a jet ski 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #625049 1st Mar 2022 6:55am
