Home > Technical (L322) > 4.4 TDV8 awful mpg? |
bluebottle Member Since: 16 Apr 2021 Location: The M3 Corridor Posts: 144 |
I've just started commuting in my L322, I had the gearbox flushed, axle and t-box fluids done by Bodsy in Feb this year. She's done just over 96.5k miles. I see plenty of people on here commenting about their 30+ mpg returns.
25th Nov 2022 5:25pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
That is a bit low, can't help why...
25th Nov 2022 5:34pm |
I am trying not to let it get to me, but one of the pieces of "man maths" I did to convince myself to sell my Deafener was that the fuel economy should have been better.
25th Nov 2022 5:41pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 757 |
Firstly, I don't think that a properly calculated 26mpg is at all bad. People talking about 30+ are not generally seeing this on a daily basis and are doubtless reading off the dash too. I've had 35mpg on a good run, but I'm generally seeing less than 26 on average. There are several things which will drag your commuting figure down. Cold starting twice a day will have you below 10 mpg until the engine is warmed up. Any kind of urban driving / stop-start / climbing hills during your pre motorway phase will keep you well below 20 as well. Finally, if you really want to see it improve, keep your motorway speeds to about 60mph. If 26mpg is a deal breaker, you're definitely in the wrong vehicle. The older I get, the more I realise that people confuse wrinkles for wisdom |
25th Nov 2022 5:43pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3255 |
Sounds about right for the type of journey you do. I'm averaging about 33mpg ( calculated from fill vs odometer) but that's mainly long M-way trips under 70mph but it drops significantly if I have to do anything on normal roads. 2012 TDV8 Vogue (L322) |
25th Nov 2022 5:59pm |
The odometer is set to be 7% optimistic and can be made accurate with a GAP IID tool. What tyres do you have? 2012 TDV8 Vogue (L322) |
25th Nov 2022 6:30pm |
francy Member Since: 30 Jul 2012 Location: northwest Posts: 76 |
My TD6 does 24.6 around town and has very low miles on clock less than 70,000 mil so them who say over 30 in short journeys take it with a pinch of salt car weight nearly 3ton |
25th Nov 2022 7:24pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1478 |
I've got a 4.4 TDV8 and these are the typical MPGs (I drive at the speed limit, plus a few )
25th Nov 2022 9:26pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Sounds about right TBH, you can get 35 plus MPG on a long run taking your time, but reality mine has done 24.8 over 7500 miles, including some towing, yours sounds about right if it’s overall mileage. |
25th Nov 2022 9:44pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
How do we do this, for those of us with IID tool?. visiting from www.rrsport.co.uk |
26th Nov 2022 6:30am |
Tiny Timmy Member Since: 04 Sep 2013 Location: Bucks Posts: 172 |
26th Nov 2022 6:56am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
25-28mpg is my average over 105k miles (had mine since new….i reckon it has another 12 years left in it)
26th Nov 2022 11:31am |
CCF - instrument pack - mpg offset to zero. 2012 TDV8 Vogue (L322) |
26th Nov 2022 11:41am |
Thanks people - I love the car and 26mpg is not a deal-breaker, particularly since it's a 300bhp engine powering a 2.7 tonne vehicle.
26th Nov 2022 9:19pm |
