Home > Technical (L322) > 4.4 TDV8 awful mpg?
bluebottle
United Kingdom 2012 Range Rover Vogue SE TDV8 Buckingham Blue
4.4 TDV8 awful mpg?
I've just started commuting in my L322, I had the gearbox flushed, axle and t-box fluids done by Bodsy in Feb this year. She's done just over 96.5k miles. I see plenty of people on here commenting about their 30+ mpg returns.
My commute is about 30 minutes with around 15-20 minutes of that on a motorway at genuinely no more than 70mph. After two weeks I've done 434.8 miles and today she took 80.21L of diesel to the 'click'. That's 24.6mpg. My 2005 TD5 110 Defender did better than that. In fact, over the 12.5k miles I've owned this vehicle the average is 26mpg.
Have I got some sort of problem or is everyone else just posting figures from the dash trip computer (which should frankly be in Parliament given its very limited relationship with reality)? 2012 L322 TDV8 Vogue SE: Buckingham Blue
2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten
Post #649125 25th Nov 2022 5:25pm
That is a bit low, can't help why...
Just for info if you have an IID you can trim out the on board computer to make it read accurately. Thumbs Up Pete
Post #649127 25th Nov 2022 5:34pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
That's about right. Those who claim over 30 are normally low speed, longer haul drivers with time for the engine to warm up (they run quite cool normally). I averaged 31 on a trip up to Yorkshire and back from Bristol. However my 10 mile commute into town (25 mins with 10 mins on motorway) only gives me an avge of 24-25 mpg. The killer is the stop start in town.
Best thing is not to let it worry you. Even getting up to 30 mpg will only save you 5p per mile in fuel cost. simply sit back and revel in the fact that you are cocooned in one of the best cars on the road.
Post #649128 25th Nov 2022 5:36pm
bluebottle
I am trying not to let it get to me, but one of the pieces of "man maths" I did to convince myself to sell my Deafener was that the fuel economy should have been better.
You're right though, while the 110 had more character it didn't have a fuel-burning heater, heated steering wheel and a Harmon Kardon sound system. 2012 L322 TDV8 Vogue SE: Buckingham Blue
Post #649129 25th Nov 2022 5:41pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Re: 4.4 TDV8 awful mpg?
Firstly, I don't think that a properly calculated 26mpg is at all bad. People talking about 30+ are not generally seeing this on a daily basis and are doubtless reading off the dash too. I've had 35mpg on a good run, but I'm generally seeing less than 26 on average.
There are several things which will drag your commuting figure down. Cold starting twice a day will have you below 10 mpg until the engine is warmed up. Any kind of urban driving / stop-start / climbing hills during your pre motorway phase will keep you well below 20 as well. Finally, if you really want to see it improve, keep your motorway speeds to about 60mph.
If 26mpg is a deal breaker, you're definitely in the wrong vehicle. Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #649131 25th Nov 2022 5:43pm
JayGee
Sounds about right for the type of journey you do. I'm averaging about 33mpg ( calculated from fill vs odometer) but that's mainly long M-way trips under 70mph but it drops significantly if I have to do anything on normal roads. 2012 TDV8 Vogue (L322)
Post #649136 25th Nov 2022 5:59pm
JayGee
The odometer is set to be 7% optimistic and can be made accurate with a GAP IID tool. What tyres do you have? 2012 TDV8 Vogue (L322)
Post #649140 25th Nov 2022 6:30pm
francy
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
My TD6 does 24.6 around town and has very low miles on clock less than 70,000 mil so them who say over 30 in short journeys take it with a pinch of salt Shocked car weight nearly 3ton
Post #649142 25th Nov 2022 7:24pm
garyRR
I've got a 4.4 TDV8 and these are the typical MPGs (I drive at the speed limit, plus a few Thumbs Up )
Summer
Town: 28mpg
Motorway: 34mpg
Combined: 31mpg
Winter (bear in mind diesels aren't as economical in the winter than as the summer for various reasons for example, rain, wet road surfaces, cold weather, winter diesel mix, lower average traffic speed, increased congestion etc. The 4.4 TDV8 is a considerably larger block than a TD or Defender engine, and takes much longer to warm up)
Town (short journey): 20mpg
Town (moderate journey): 24mpg
Motorway: 30mpg
Combined: 28mpg
I would say your MPG reading sounds about right. The days have been very cold recently and that big lump takes a while to get up to operating temperatures where it's most efficient. You'll need more than a 30 minute journey for the average MPG to start climbing closer to 30mpg.
As mentioned by others, the MPG will tank in start stop traffic, again with a 4.4L block sat idling away going nowhere. 2015 Range Rover Autobiography 4.4 SDV8
Post #649159 25th Nov 2022 9:26pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Sounds about right TBH, you can get 35 plus MPG on a long run taking your time, but reality mine has done 24.8 over 7500 miles, including some towing, yours sounds about right if it’s overall mileage.
Post #649162 25th Nov 2022 9:44pm
gettingold
How do we do this, for those of us with IID tool?. visiting from www.rrsport.co.uk
Post #649174 26th Nov 2022 6:30am
Tiny Timmy
Thumbs Up Thumbs Up
Post #649175 26th Nov 2022 6:56am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
25-28mpg is my average over 105k miles (had mine since new….i reckon it has another 12 years left in it)
20 ish around town. Even in the teens.
30mpg on a long run.
I have never seen the 35s that some members see.
My economy numbers have not changed during the life of the vehicle
My tyres are AT3s
Post #649204 26th Nov 2022 11:31am
JayGee
CCF - instrument pack - mpg offset to zero. 2012 TDV8 Vogue (L322)
Post #649205 26th Nov 2022 11:41am
bluebottle
Thanks people - I love the car and 26mpg is not a deal-breaker, particularly since it's a 300bhp engine powering a 2.7 tonne vehicle.
I'm pretty sure my tyres are Pirelli Scorpion Zeros. I know Harry Metcalfe sings the praises of the Scorpion Verde - not sure what the difference is? Which are better for mpg - I don't do mud-plugging - the closest I get is my Dad's muddy field in Shropshire maybe a couple of times a year!?
Thanks for the hint with the IID tool, I'll have a play maybe. 2012 L322 TDV8 Vogue SE: Buckingham Blue
Post #649254 26th Nov 2022 9:19pm
