Home > Technical (L405) > Strange smell & slight smoke
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi all the smell this morning was shocking inside the car noticed it more when stationary obviously not very healthy to be inhaling. I got out lifted the bonnet and the wisp off smoke was coming from back centre of engine not full on smoke but slight wisping.Thoughts possibly oil cooler dripping any other ideas?
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #649435 29th Nov 2022 10:09am
GraemeS
The cross-over pipe is wrapped in a protective covering. Hence dripping oil doesn't drip directly onto hot steel pipe, instead onto hot material that causes the oil to vaporize more slowly, exactly as you describe.
Post #649438 29th Nov 2022 10:34am
jaysta10k
Thanks again for input lads much appreciated I will call garage today to take a look and update in due coarse.
Previous Cars
BMW M3 Carbon Black
Post #649439 29th Nov 2022 10:51am
jaysta10k
Hi guys took a look under car today seen a few leaks see images
and I still have the horrible burning smell in the cabin is this the oil cooler gasket issue.
Previous Cars
BMW M3 Carbon Black
Post #653030 8th Jan 2023 7:03pm
BBryant
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Reviving this one, I have a similar issue, a wisp of smoke coming out from behind the engine. I had the oil cooler done as it was leaking, its been over a month so any residue must have burnt off by now.
I found a slight drip of oil on a rubber hose on the front left underneath, I think a pipe to the oil cooler? I cleaned it off and it hasn't come back.
There is a bit of water (?) on the transmission undertray, it doesn't look like coolant or oil.
Other than that I can't find anything obvious. It usually happens after a motorway drive so the DPF regen idea is interesting, it might not be quite long enough on the motorway to complete the regen. Although I have had a couple of long drives a few weeks ago and it still comes back.
I do have a slightly warped front left brake disk but I think it smells more like burning oil than brakes.
Did you ever get to the bottom of it?
Post #692750 16th May 2024 7:15am
