Home > Technical (L405) > Strange smell & slight smoke |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2490 |
The cross-over pipe is wrapped in a protective covering. Hence dripping oil doesn't drip directly onto hot steel pipe, instead onto hot material that causes the oil to vaporize more slowly, exactly as you describe. |
29th Nov 2022 10:34am |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 295 |
Thanks again for input lads much appreciated I will call garage today to take a look and update in due coarse.
29th Nov 2022 10:51am |
Hi guys took a look under car today seen a few leaks see images
8th Jan 2023 7:03pm |
BBryant Member Since: 07 May 2024 Location: Buckinghamshire Posts: 13 |
Reviving this one, I have a similar issue, a wisp of smoke coming out from behind the engine. I had the oil cooler done as it was leaking, its been over a month so any residue must have burnt off by now.
16th May 2024 7:15am |
