![]() | Home > Technical (L405) > Strange smell & slight smoke |
SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110 ![]() ![]() ![]() |
Did it smell almost like metal? if so, could be a re-gen 2019 L405 SV Autobiography |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi Martin would a bad re gen cause a slight wisp of smoke also? How would you cure this also a bad re gen
Hi ya, not a bad regen, just a normal regen. The exhaust system gets VERY hot during a re-gen so any debris, dirt, etc. that's on it could smoke etc. Drive the car again, let it get hot with over 1/4 tank of fuel. if it does it again, check if your MPG has dropped through the floor. if it has, its a re-gen. If it is, get on a motorway if you can, put it in manual mode, and drive it for about 20 mins over 2000rpm. That will clear it. 2019 L405 SV Autobiography |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 ![]() ![]() ![]() |
Oil cooler leaking into the "V" perhaps? Common issue on the 4.4 V8 diesel.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Don’t think it’s a re gen issue as MPG all good doing 90 miles a day round trip so car being used on long journeys etc..Just strange as it smells similar to break caliper sticking but they are fine breaks recently changed all round so all good. Smell is only really noticeable outside car by drivers side. And also when sat in traffic with window open can smell again from drivers side. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 ![]() ![]() ![]() |
Just a thought, your FBH is front drivers side, that hasn't been on when it shouldn't be has it..?? Pete
Good shout!!!! It comes on to warm 4.4 up 2019 L405 SV Autobiography |
Thought the FBH only came on when the remote is pressed or set within the cabin on a timer to come on. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
FBH will come on automatically if ambient temp is below cerca 10C to assist engine / cabin temp to warm up. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2555 ![]() ![]() ![]() |
My bet is the aforementioned leaking oil cooler, either the gaskets or the o-rings for the oil pipe or both, causing oil to drip onto the cross-over pipe primarily on the right side. |
How long does the FBH stay on for this to assist with warming up cabin. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack Audi A4 2.7 TDI S Line Black Edition phantomn black Previous Cars Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded Java black Range Rover sport 2.7 TDV6 Alaska white Range Rover sport overfinch 3.6 TDV8 BMW M3 Carbon Black |
cheers for this I will look into this also as the smell is starting to @@@@ me off now! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack Audi A4 2.7 TDI S Line Black Edition phantomn black Previous Cars Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded Java black Range Rover sport 2.7 TDV6 Alaska white Range Rover sport overfinch 3.6 TDV8 BMW M3 Carbon Black |
Look underneath at rear of engine area for leaks.
TBH I can’t remember the exact numbers but it stays on till the engine is almost to running temperature if the ambient temperature is low. It is all in the workshop manual which gives all the parameters it kicks in and out at, some good bedtime reading. ![]() |
