Home > Maintenance & Mods (L405) > LED Lightbar Install
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
Whilst I am not a pioneer, thought I post a few photos from my light bar installation. Has turned out to be a very elegant and discreet spotlight solution.
I used a Blackoak 30 inch curved LED bar which amazingly lines up perfectly with two of the bumper bolts. It's depth is also perfect to sit snugly behind the grille.
Was happy to do the mounting myself but took it to an auto electrician with Range Rover experience to wire it up.
Post #648396 18th Nov 2022 4:23am
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
That’s a very neat installation. Looks like a perfect solution to the poor output of the pre-2018 lights without spoiling the looks. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #648402 18th Nov 2022 8:21am
Very similar to my install… I’m working on a can-bus relay solution atm to allow it to only come on at a pre programmed speed! So say above 40 or 50mph so your not dazzling other drivers unnecessarily at slow speeds… 👍
Post #648424 18th Nov 2022 10:22am
SVAuto_Man
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Hi Craig,
You wouldnt have a list of CAN messages would you Wink 2019 L405 SV Autobiography
Post #648426 18th Nov 2022 10:36am
I’ll be able to get it I’m sure sir… Not my department, but yes it will have to be decoded if not done already?
Post #648433 18th Nov 2022 12:00pm
SVAuto_Man
Hi, that would be fab, something I have been after for years! 2019 L405 SV Autobiography
Post #648435 18th Nov 2022 12:12pm
fisha
That looks a great fit in that space. Do you feel the grill affects the light pattern as is you see darker parts cause its blocked, or is it all quite even? V8 or else ...
Post #648479 18th Nov 2022 7:36pm
Salsbury
Light distribution is quite even. No grille pattern is projected as far as I can tell.
Probably helps that it's a double row light bar. The center section is spot with a 15 degree vertical spread and the sides are flood with a 45 degree vertical spread
Post #648486 18th Nov 2022 8:18pm
