Home > Maintenance & Mods (L405) > Deployable Steps Trim |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
The trim on my car is short and the steps come with extra length to protect the steps and look neater, I had front mud flaps fitted and they have to be changed to fit the extra length cover. |
7th Nov 2022 12:19pm |
SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110 |
Hi ya,
7th Nov 2022 12:23pm |
Normal Autobiography. I take it you tried Duckworths. |
7th Nov 2022 12:26pm |
Hi ya,
7th Nov 2022 12:29pm |
Did you get the extra protection bits of plastic, and when you ordered did you give them all the specs of your car? |
7th Nov 2022 12:45pm |
I have got the bits all separate. On TOPIX, its the kit listed for my car and the plastic trim doesnt match the car.
7th Nov 2022 1:16pm |
I have sent you a PM |
7th Nov 2022 1:37pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
SV man, they do NOT make the part you're looking for, unfortunately... That panel is only made for the standard body type NOT the SVO kit sir... |
8th Nov 2022 12:44am |
Hi ya,
8th Nov 2022 8:04am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 873 |
I think you’ll need the standard panel with the cut out, as the step when retracted sits into this recess, which your SV panel may not have? |
8th Nov 2022 8:24am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35427 |
thinking outside the box here, what about cutting a little bit off the step where it would recess into the trim... ... - .- -.
8th Nov 2022 8:27am |
From what I spotted online, with the SV trim the step sits almost on top of it. The standard trim just adds a bit to blend it in more.
8th Nov 2022 9:07am |
There is no need to cut anything as they can move on the fixings forward /backwards.
8th Nov 2022 9:30am |
Another option is use some of the bits that are for the RRS.
8th Nov 2022 9:34am |
