Home > Maintenance & Mods (L405) > Deployable Steps Trim
SVAuto_Man
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Hi All,
In the process of getting the last bits for me to fit deployable steps to my 2019 SV.
Have everything now but one thing that's shown in the kit instructions, front fender trim.
The instructions list VPLGP0134 but it looks different than whats on my car as I have the SV body kit.
Anyone know if there is another part or if its not required etc.
Post #647574 7th Nov 2022 12:58pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
The trim on my car is short and the steps come with extra length to protect the steps and look neater, I had front mud flaps fitted and they have to be changed to fit the extra length cover.
Post #647580 7th Nov 2022 1:19pm
SVAuto_Man
Hi ya,
Can not find any trim for cars with the SV body kit. Do you have the SV body kit or normal style?
Cheers!
Post #647582 7th Nov 2022 1:23pm
Tinman
Normal Autobiography. I take it you tried Duckworths.
Post #647584 7th Nov 2022 1:26pm
SVAuto_Man
Hi ya,
Will try them now. The local dealer here said there isn't one, don't use anything.
I guess the worse case if I did want to use something, have to get the extra bits and the standard painted infill and paint the whole lot as there is no black plastic on the SV body kit.
Post #647586 7th Nov 2022 1:29pm
Tinman
Did you get the extra protection bits of plastic, and when you ordered did you give them all the specs of your car?
Post #647590 7th Nov 2022 1:45pm
SVAuto_Man
I have got the bits all separate. On TOPIX, its the kit listed for my car and the plastic trim doesnt match the car.
I asked the dealer, who has my VIN etc, is that the only trim and they said yes. They said all the ones they had seen had nothing changed at the front etc.
Post #647594 7th Nov 2022 2:16pm
Tinman
I have sent you a PM
Post #647595 7th Nov 2022 2:37pm
SV man, they do NOT make the part you're looking for, unfortunately... That panel is only made for the standard body type NOT the SVO kit sir... Bow down Thumbs Up
Post #647644 8th Nov 2022 1:44am
SVAuto_Man
Hi ya,
Yeah I guessed so as nobody knows of anything. Will see what it looks like with them fitted. Might be a case of getting the one listed above and the painted insert and fully painting it all.
Post #647648 8th Nov 2022 9:04am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I think you’ll need the standard panel with the cut out, as the step when retracted sits into this recess, which your SV panel may not have?
Post #647649 8th Nov 2022 9:24am
thinking outside the box here, what about cutting a little bit off the step where it would recess into the trim... ... - .- -.
Post #647650 8th Nov 2022 9:27am
SVAuto_Man
From what I spotted online, with the SV trim the step sits almost on top of it. The standard trim just adds a bit to blend it in more.
Post #647651 8th Nov 2022 10:07am
Tinman
There is no need to cut anything as they can move on the fixings forward /backwards.
the only option is fit nothing extra and sees how it looks for you, but it will show you have steps, as always it's a personal choice Thumbs Up
Post #647654 8th Nov 2022 10:30am
SVAuto_Man
Another option is use some of the bits that are for the RRS.
Part V and R and S
Post #647655 8th Nov 2022 10:34am
